Unable to import converted model
All  1-13  14-19
5006.14 In reply to 5006.13
What is the % of users who has really need this ASM format?
5006.15
Paul, which version of Deep Exploration are you using, Standard or CAD Edition?
If you're using the Standard Edition that would explain why the output is a polygon mesh.
BTW: An Engineer that thinks it's too hard to output an IGS or Step file from Solidworks,
needs to go back to school! :P
5006.16 In reply to 5006.14
I don't know the exact % number, but it does not seem to be requested very often though.
Most of the time STEP and IGES formats tend to be used for data translation between CAD programs, so usually the CAD operator will know to export to one of those formats if the model is going to be transferred to some other system.
5006.17 In reply to 5006.12
Asking the engineer for the original is like asking a pro photographer for the pictures. They will give prints, etc, but not the original. It would be like cutting him out of the loop of his work.
With that being said, An "ASM" file is an "assembly" file and may contain "Part" files from several different systems. Breaking down the assembly and getting at the original model, which could be several different formats from several different systems, could be a lot of work, and also present translation issues if the "assembler" doesnt have access to the original part creation software.. You may be asking the engineer to sit down and do several hours worth of work, to get you the part exported out.
5006.18 In reply to 5006.17
I have always ask pro photographers for the original, especially when they expect good output.
For legal reasons, you can always set up a NDA, CA, CDA, PIA etc.
The point is if everyone co-operates then no one (usually contractor/subs) have to put in time for free,
and let's face it, if the engineer/photographer could do the service you offer for the price you
charge, then why would they be coming to you in the first place? =)
More than anything, it's about co-operation and respect in the age of specialization.
5006.19 In reply to 5006.18
""""""""""and let's face it, if the engineer/photographer could do the service you offer for the price you
charge, then why would they be coming to you in the first place? =)""""""""
I suppose that would be the point. Asking the engineer to do a bunch of heavy lifting to get you the model, when he already told his boss it would be $1000, not $200. So the engineer sends an OBJ/STL and says, "good luck"....
Show messages: All  1-13  14-19
