retain line information on export
All  1-4  5-8
5002.5 In reply to 5002.4
Micheal,
thanks but no such luck. The programs keep seeing them as splines which I can change to bezier which makes a mess of the line. Can you recommend a program (that doesn't cost an arm and a leg) that can recognize a nurbs curve as a circle? I had turbocad 8 pro from years ago and tried doublecad as it was free to hoping they had updated things. All I'm doing is 2D line work that I'm laying down the dimensions.
Thank
Val
5002.6 In reply to 5002.5
5002.7 In reply to 5002.6
Another, roundabout option:
Download the trial version of Rhino (it will save up to 25 times)
Open your MoI file with Rhino and save it as a .dwg file.
Then you can open it with Draftsight (a free program) and add your 2d dimensions.
good luck.
eric
5002.8 In reply to 5002.7
Hah, Changing the N to Y does work. for whatever reason the save wasn't kicking in, in notepad. I saved it but it would reverse back. I had closed out Moi before I opened the ini...... Anyway work like a charm. This time it seems like it took.
thanks
Val
Show messages: All  1-4  5-8
