Hi Danny,
> Just jumping in on this, what would be the case with naming
> when we do a 'Rebuild' on the curve?
That's a different kind of case since the Join case has the situation of 2 different objects coming together into 1 object and so it needs to pick which of the 2 input objects names to use.
For Rebuild there is a new object created in a more 1-to-1 method, so the new object gets the same properties (same name, same style, etc...) applied to it as the original same as if you just copied it.
Are you having a problem with Rebuild where the rebuilt result is not maintaining properties like that?
