surface trim problem
All  1-6  7-9
4995.7 In reply to 4995.5
Hi again..
..well, an issue might be, that the circle(green) and the surface(red) are actually not on the same plane/level (check Top)..there's a tiny tiny gap..
I'm sure, that Michael will come up with some helpful explanations.
Cheers,
Marco(..upps..too late..:])
4995.8 In reply to 4995.7
Hi Marco,
That's so tiny that I don't think it's the issue - check out the message just slightly above, I posted it at the same time you were writing your other post I think.
It definitely looks to me like a display mesh generation problem - the bottom edge is just slightly curved but the display mesh just puts a straight line on it and so the outer and inner boundaries end up crossing each other in generated display mesh and that then makes for the messed up display mesh appearance.
As far as I can tell the actual result of Trim in the NURBS geometry itself is all ok.
There's more explanation and some screenshots to illustrate above.
4995.9 In reply to 4995.8
Thanks for bailing me out, Marco and Michael. I find the forums invaluable!
Randy
Show messages: All  1-6  7-9
