color
4989.1
Hi ...
Is it possible to turn the color off in all styles simultaneously so that there is simply a line drawing?
I know that can be done individually by changing the style color but my template includes about 60 styles and sometimes I would like to simply present a line drawing with no color faces.
thanks,
eric
4989.2 In reply to 4989.1
Hi eric,
You can override how colors are displayed so that everything shows in one fixed color rather than using the actual style colors.
For that go to Options > View > Colors - there are settings there for "Surface color" and "Edge color":
By default those are set to "By style" so that the object's assigned style color is what is used for displaying it. But you can use the dropdown there to change it to "Fixed color" after which a color swatch will appear next to the dropdown and you can use that to set the color that will be used for the surface or edge display instead of using style colors.
If you use that setting to override the display it should be easier than actually changing all your style colors, because it is easier to revert the setting and restore things later on.
Hope that helps!
4989.3 In reply to 4989.2
Perfect Michael ...
Thanks, that is exactly what I wanted to do. I should have noticed the option ... I have used the 'edge color' utility but did not see that I could do that with the surface color option.
A blind spot, I guess.
cheers,
eric
