is there a method of setting the STL export defaults?
All  1-2  3-6
4984.3 In reply to 4984.1
And if instead of having your settings persist you instead want to set what the defaults are, you can modify some of the other settings under the [Mesh Export] section, there are a bunch of ones that are empty but if you set them that will set the default, look for the ones like:
Angle=
DivideLargerThan=
DivideLargerThanApplyTo=
AvoidSmallerThan=
AspectRatioLimit=
If you add a value to the right of the = sign on any of those that should set the default.
4984.4 In reply to 4984.3
thanks Michael, for both options :)
4984.5 In reply to 4984.3
Hi Michael
If I set DivideLargerThanApplyTo=All in the ini file , STL export it still defaults to Curved
OSX 2.5 beta, no big deal, just thought I'll let you know. :)
4984.6 In reply to 4984.5
Hi steve,
Try setting it in lower case, like this:   all
That can be one of:   curved   planes   all
It's not supposed to be case sensitive though, there seems to be some bug there I will take a look. But for now anyway if you put in: all it looks like it will work.
Show messages: All  1-2  3-6
