Scratch, a free program
All  1-3  4-11
4975.4 In reply to 4975.3
Hi Burr, use HTML style <> brackets for the tag, so like this:
<code> .... <code>
I tweaked it for you.
Thank you Burr & Michael.
Like other scripts, the scripts will work 2 ways:
1. Tab paste return.
or 2. Make an Option Shortcut key. I used Ctrl+Shift+S.
Was going to make a spherical spiral script, but no need, forgot about twist.
Here is half an ellipse, with twist, and sweep:
Picture is very large... :-)
EDITED: 2 Apr 2015 by BEMFARMER
4975.6 In reply to 4975.4
Got it! Thanks Michael.
4975.7 In reply to 4975.5
Hi Bemfarmer,
Here is another script. This one will allow you to capture the viewport to the clipboard, at a specified size (Set in the script here as 2560x2560). You can then paste the image into any app that accepts the paste. So modify the numbers to get an image of a desired size, or make a progressive set to use.
script: /* render view to clipboard */ var v = moi.ui.getActiveViewport(); if ( v != null ) { moi.view.lineWidth = 4; v.renderToClipboard( 2560, 2560 ); moi.view.lineWidth = 1; }
Remember that your video card will limit the size you are able to capture. So you wont be able to capture a 6000x6000 pixal image unless you have some good video power.
4975.8 In reply to 4975.7
Thank You.
http://byob.berkeley.edu/ With BYOB you can new Bricks of instructions if Scratch is not sufficient ;)
You can make an exe from a scratch project!
http://scratch.mit.edu/forums/viewtopic.php?id=46159
cut the sound ;)
Show messages: All  1-3  4-11
