how does planar and bend work?
All  1-2  3-4
Take care of the position of the click! :)
496.4 In reply to 496.3
Just a quick note - this will be different in the next beta. In the next beta it will always do the automatic calculation for aligning the blended surface. But before you finish the blend you will also be able to flip any edge to allow you to fix up any cases where the automatic matching did not do a good job, which is relatively rare but can happen in some arrangements.
This same thing will apply to Loft in the next beta as well. So I think that will reduce one common area of confusion.
Also I've completely rewritten surface blending so it will generate a lot better quality surfaces for this next beta. In the current beta it can generate pretty poor results in a lot of cases.
Show messages: All  1-2  3-4
