is the a way to draw permanent construction line? ( until I want to delete them :) )
All  1-4  5-7
4957.5 In reply to 4957.4
Thanks Michael, I think that script does what I need, what I was thinking with the circle, was this, from ArrayGem,
"The center of the base circle will become the point that is placed on to the surface" i.e the centre of the circle will be placed on the target point.
Cheers, Steve
you can also use any curves with a special colors that you can hide at any time!
EDITED: 23 Feb 2012 by PILOU
4957.7 In reply to 4957.5
Hi Steve,
Yeah I think that CopyToPoints should do what you need - in the first step of that command you pick the base point for what spot on the object you want to have located on the target point, like the Transform > Copy command.
But then instead of clicking new points with the mouse for where to copy the object to, the CopyToPoints plug-in lets you select point objects and then uses those for the target locations.
Show messages: All  1-4  5-7
