right side or top side when drawing?
 1-7  …  28-47  48-67  68-87  88-92
4950.68 In reply to 4950.67
Thanks for telling me how to do this step. This should be better.
Tony
Hi Tony,
Here is a quick sketch of your measurements.
Cannot understand the arc location without pictures...
It might help to provide the center to center spacing of the two butt bolts,
Also the overall length from butt to trigger end, say at 90 degrees from the butt line.
The length from the butt to the flat at the (top or bottom?) of hand grip also.
Then the pictures could be scaled.
EDITED: 2 Apr 2015 by BEMFARMER
4950.70 In reply to 4950.68
Hi Tony,
The 3dm still shows up, for me, with no pictures...
EDITED: 18 Mar 2012 by BEMFARMER
4950.71 In reply to 4950.70
Did this one work?
With the length of the stocks varying several inches in length from one order to the next, I planned to zero from the right back region which is where the metal fits in the grip and is the constant. The top portion of the arc on the top right portion is about .4" behind the metal.
The bolt holes on the left side are 3.1" apart-but this varies with different recoil pads.
I have fixtures holding the wood up off the table since the wood thickness varies.
With the variations in length as well as thickness of grip region in most orders, I see the machine doing the rough shaping and the final shaping will allow for the variations.
Tony
4950.72 In reply to 4950.71
It opened on mine with changing the "open with" to a cad type wording.
Pretty nice to move the three around and size them better.
Tony
Here is the easy part, outline of a center plane. (other two pictures removed.)
Do not have a cross section of the butt end...
I suppose the pictures introduce a bit of distortion?
The front picture seems to be of a different stock? Was not able
to align it very well.
Got to quit for now...
Edit, used Options icon at bottom of screen to set units to inches.
4950.74 In reply to 4950.73
hope this helps or do they need to be on same attachment?
Tony
4950.75 In reply to 4950.74
Pistol grip....
Butt profile
EDITED: 19 Feb 2014 by BEMFARMER
Excellent grip tutorial!
4950.78 In reply to 4950.77
Thanks a bunch. I can only open the attachments from my shop computer so I have not been able to watch the last couple. Looking very forward to Tue afternoon when I should get time back in the shop.
The right picture showing the front of the stock was of the same stock, but very hard to get it accurate. What do I do with the right picture, and how do I line up and connect them into a solid?
I will need to practice a lot. The icons used to get the pistol grip region finger grooves will work on the stock picture as well correct?
Tony
4950.79 In reply to 4950.78
Wow, Bemfarmer and Burrman, you have shown me a lot of stuff needed. Thank you very much. I will be practicing later today. BemFarmer, how did you get the curve lines for the behind the grip region?
I also am not sure, how did you use the right side picture of the front of the stock to help this process?
Tony
4950.80 In reply to 4950.79
Hi Tony,
Well, I cannot claim that anything I did was the "proper" or best method...
The curved region was done using the tree rings as "contour" lines, like in a terrestrial map of elevations.
This assumes that the grain was straight and parallel to the center plane of the stock, which may not be true, but
given the taper of the left of the stock, and the way the tree rings taper, it looks fairly parallel.
So the curved portion should be more or less accurate. They may need to be redone, or made less shallow...
In Top view, placed a lot of dot points along a curve. The leftmost dot was placed at high z, starting from the far left loft. The rest of the dots occur at z = 0.
In Top view, starting with the high z dot, doing a freeform arc through all the dots, created a curve with constant high z value. The curve did NOT drop down to the center plane. Then did lofts or sweeps... This was time consuming, and the result less than perfect.
The naked edge test showed a lot of edges, so some fixing may be needed...
The two rounded, right hand red extrusions were quick and easy. In Right view, the right end picture was aligned to match the base of the handgrip, and
the top (back) of the rounded area. Then the thickness was estimated, and one (or two) rectangles made. The rectangle is extruded to be larger than the
front rounded area. Then the centerline top profile of the rounded section was extruded in the plus and minus z directions, beyond the red areas, and used
as a boolean difference to trim the red 3D rectangle solid. (A common and good technique). (Had some trouble with disapearing red portions, so should have just done one red block, and then copy it...)
Made an assumption that the stock is not right handed. (That the bottom half is symetrical with the top half.)
4950.81 In reply to 4950.80
Ok. I am getting the feel for using the pictures in the back ground. But, now how do I bring them together to see what it looks like before going to far.
Tony
4950.82 In reply to 4950.81
Hi Tony,
In my opinion, it is a good idea to scale the photos, and move them so that they match up with each other, using the view,image,align command.
It helps me to place points at certain areas on the photos, say two points per photo, say 1 point at left center, 1 point at right center.
Also place a start and an end point on the MoI screen, at known lengths, where the stock will be created.
The align command takes a little bit of practice, but is fairly easy...
Pick the two points on the photos, then pick start point on the screen, and the endpoint on the screen.
The photo is scaled and can also be rotated a bit, if it is slightly askew.
Lots of saves helps, as going backwards may be limited. Setting up the incremental save script is handy. (Alt+S).
(Just one amateurs opinions.)
There is going to be some distortion and slightly angled photos, so the photos are a guide, not perfection...
4950.83 In reply to 4950.82
Thanks. I forgot to do the left/butt drawing as well.
I use loft to connect the 3 planes correct?
More practice tonight.
Tony
4950.84 In reply to 4950.83
Another question, do i need to draw a drawing in the back screen as well?
Tony
4950.85 In reply to 4950.84
Hi Tony,
I think that a photo of the back side of the stock would have valuable data for forming the grip/trigger end, depending upon how
much detail you are creating... A lot of measurements of distances and curvatures might help too.
The impression is that you are aiming for say 80% of the finished product?
IMHO it is not a matter of putting up 4 or 5 pictures, pushing the loft button, and having a finished model.
The loft tool is helpful, and perhaps sweep and network as well... etc.
4950.86 In reply to 4950.85
when I try to put the back picture in the window, the front picture is there and I can figure out how to delete the wrong picture for the screen. Help needed with this one.
80% would be more than enough for now while I am learning.
Tony
4950.87 In reply to 4950.86
Under view image, select a jpg, and hit the show/hide button.
Show messages:  1-7  8-27  28-47  48-67  68-87  88-92
