move from Moi to Vertric cut 3D?
All  1-6  7-10
4939.7 In reply to 4939.6
Ok, here is what I am experiencing.
I can save the file in Moi, but when I try to pull it up in Vectric Cut3D it replies "requested file not found".
When I save it in Moi as a STL file and it wont open in Vectric Cut3D Is there something I am missing with the stl format and the mesh vs polygonal format????
Thanks for helping me out.
Tony
4939.8 In reply to 4939.7
Maybe set your vectric icon to run as administrator.
4939.9
Are you running the demo version of Cut 3D? If so, they only allow you to open the models that came with the demo program.
4939.10 In reply to 4939.7
Hi Tony,
And you're sure that you have an actual solid in MoI before exporting, not just a curve wireframe, right?
If you just have a regular STL file and Vectric Cut3D will not open it you will probably need to ask on the vectric forum for some help with that, their forums are here:
http://www.vectric.com/forum/
Or are you running the demo version like Bob mentions above?
Show messages: All  1-6  7-10
