Transparency
All  1-3  4-7
4935.4 In reply to 4935.3
Hi Martin!
by "guides" do you mean the GRID or the CLINEs? CLINES(ConstructionLines) should be visible all the time..you could check, if DISPLAY HIDDEN LINES in the OPTIONS panel is checked.
~Marco
4935.5 In reply to 4935.4
Oops ambiguous question ... The thing i am after is more like a ghosted surface. Example would be vehicle outline. blueprint etc, when you are modelling say the door curves and surfaces, I have to hide the resulting surface because i cant see the door handle recess or the keyhole. It's not a problem hiding things but it would be easier if i could see through the surface.
TpwUK
4935.6 In reply to 4935.5
Ah, i see..well for blueprints/images, you could fiddle with the DRAW and TRANSPARENCY settings in the IMAGE tab to get a kind of '"ghosting" behaviour..
~ marco
4935.7 In reply to 4935.6
Spot on! - Nice one Marco
Many Thanks
Martin Spencer-Ford
Show messages: All  1-3  4-7
