Humble script request
All
1-14
15-19
bemfarmer
15 Feb 2012 (15 of 19)
4930.15
Got the CantedHelix script to work.
It was necessary to adjust the formulas.
(The use of w had to be modified.)
EDITED: 15 Feb 2012 by BEMFARMER
CantedHelixDone.7z
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
bemfarmer
15 Feb 2012 (16 of 19)
4930.16
In reply to
4930.15
Picture:
I suppose it could be turned into a toroid, without too many hours of work?
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
15 Feb 2012 (17 of 19)
4930.17
In reply to
4930.16
Hi Brian, yeah what about using Flow to bend it around a circle like you showed earlier in this thread?
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
bemfarmer
15 Feb 2012 (18 of 19)
4930.18
In reply to
4930.17
Flow should work great!
I'm curious if the skewed helix is the same as a canted one...
The script does't set the length like the MoI helix command can...
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Morten (RUMLAB)
16 Feb 2012 (19 of 19)
4930.19
In reply to
4930.18
Yes, these are very cool springs! Making a lamp that can twist... Still very much in progress.
The script works perfectly in combination with the Flow function.
Thank you very much, both of you.
Best,
Morten
EDITED: 16 Feb 2012 by RUMLAB
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-14
15-19
