problem with blend (it could be user error)
 1-20  21-40  41-42
4926.41
Found the problem. I tried rebuilding the suction and pressure side curves as well as the trailing edge radius (ter). I added roughly double the points to each and everything worked. I will update the screencasts on my youtube page in the coming days.
Update; Unfortunately, the above did not entirely fix the problems. Later on operations failed to create good geo. So I'm still going to have to play around and see what exactly causes so much variability.
4926.42
I found the problem. If I rebuild most of the lines, arcs, and circles used throughout the entire modelling process everything works fine. I did not need to scale the ter up at all.
Latest pictures are available at; http://propdesign.weebly.com/screenshots.html
Latest screencasts are available at; http://www.youtube.com/user/propdesignsupport/
Show messages:  1-20  21-40  41-42
