spline patching horror
All  1  2-8
4924.2 In reply to 4924.1
Hi Rogurt, can you please post the 3DM model file that you are talking about instead of only a screenshot? It is much easier for me to look at a 3DM file that I can actually zoom in on and look at from different angles, etc...
But it kind of sounds like you are trying to construct things in a "patch by patch" basis, which is not the optimal way that you should usually be trying to use with NURBS modeling.
Instead you want to be creating larger chunks of your model as single broad surfaces, and then some edges are introduced by cutting some of those extended pieces, rather than trying to build the entire final edge wireframe from the start and then patching that in one piece at a time.
See some of these previous discussions on this topic:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4891.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=4872.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=4751.12
http://moi3d.com/forum/index.php?webtag=MOI&msg=4360.10
4924.3 In reply to 4924.1
> I trim them with one another mutually and create the network
> patches one by one.
This is your problem, you will not get good results by doing it in this kind of fragmented approach.
> The result should be a perfect shading sphere, no?
No - think of the network as being more like a kind of membrane that is stretching between your wires. If you have a large continuing membrane then that makes for a smooth thing, if your membrane abruptly stops in one spot instead of continuing on then there will be evidence of the stopping area in the resulting shape.
Also see this previous post for some other examples:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1398.19
If you want something to be smooth the best way to do it is to build one large surface for it rather than trying to do it in small separate patches.
4924.4 In reply to 4924.1
Basically if you want to build a model using a method of shaping one small area at at a time out of a larger smooth surface, then you should be using sub-d smoothing in a polygon modeler for that type of an approach rather than trying to do that with a NURBS modeler.
The strengths of a NURBS modeler are when you create large sections of your model out of curves that you draw, with some curves making broad extended shapes and other curves slicing away some parts of that broader shape to make holes and more irregular outlines.
If you are not able to model with that kind of an approach then it usually means that your project is better suited for a poly modeler and you're going to be struggling a lot trying to do it in NURBS since you are trying to use a different workflow than the one that is most suited for NURBS modeling.
4924.5
Here´s the scene file
4924.6 In reply to 4924.5
Thanks for your explanations Michael. What I need to do in the end will be a hiking boot very much like this:
http://upload.ecvv.com/upload/Product/20095/China_Men_Hiking_Shoes20095182102462.jpg
The 3D model of the predecessor was made with rhino. So I thought it would also be possible with MOI...
I cannot come up with a plan to make it without spline patching. Is there a better and simpler way?
Cheers,
Rogurt
4924.7 In reply to 4924.5
Hi Rogurt,
If you turn on surface control points it should help you to see what's going on there:
So note there that the control points are not all one parallel plane slices - the middle row of 3 control points are on a plane but their plane is rotated a bit. It's often that kind of rotation or wobbling of the internal structure of the surface that makes for a bit of a bulging shape where it ends. The same effect does not really create as much problems when you make an extended larger shape instead of separate small patches like this.
The canonical way to build a sphere shape in NURBS is as a surface of revolution and not by Network.
Also working with 3 sided areas can add in more difficulties, since NURBS surfaces are inherently 4 sided things, so to make a 3 sided patch one side is compressed to a point and that often makes for some slightly different shaping behavior in the direction that collapses down like that (although not with Revolve).
It is actually possible to surface your sphere here patch by patch if you use Sweep instead of Network - if you select this curve here as the profile for the sweep:
Then run Construct > Sweep and pick the other 2 adjacent curves for the rails. This will initially generate the same kind of slightly bulged thing like this:
But with sweep for some particular cases like this you can enable the "Maintain tangent" option which will construct the sweep all out of parallel planar sections, which basically avoids wobbling the shapes as the travel along the rails. That will generate the kind of result you were looking for:
If you turn on surface control points for this result you can see the difference:
Also note though that the surface is a lot more complex and dense, with the sections restrained to only be on parallel planes it usually requires a lot more of them to be used to generate a surface that matches close enough to the rails.
So it's not a way that I'd recommend for actually building a sphere - a surface of revolution is more accurate and also lighter at the same time.
But I hope that this may illustrate to you why you get the results that you were confused about - when the surface is marching along in 3D in a totally generic way like with network there is no special restriction for its structure to be all on parallel planes and that kind of general rotation is what causes the kind of bulged shapes at the edges that you were seeing.
I've attached a new version of your 3DM file that was built in octants using this particular sweep method instead of Network.
4924.8 In reply to 4924.6
Hi Rogurt,
That's going to be a very challenging model to create from NURBS - you'll be basically operating outside of the easiest areas of having much of the model defined well by 2D profile curves so you'll instead be needing to work more all with 3D curves and using the most advanced areas of the toolset.
It's a much more complex area to get used to, so it's something that you are likely going to need to invest a lot of time to get good at.
Things that are at that level of difficulty I just generally think can be better off done with a polygon modeler, sub-d modeling with a polygon modeler is much more oriented towards working all with 3D sculpted type shapes moreso than MoI is.
It might be technically possible to do in MoI, but it's at such an advanced, difficult, and finicky area of NURBS modeling that it has not been a big focus in MoI to target that kind of modeling, since it's generally better handled by sub-d modeling instead.
Also when you get to this kind of advanced surface level of work there are some additional tools that Rhino has that are not in MoI yet for editing surfaces to be smooth to one another, like the MatchSrf command in MoI. So if you need some of those specific kinds of tools you will need to use Rhino in combination with MoI to fill in some of those kinds of functions.
I do want to add those advanced surfacing type of functions into MoI as well, but it has been a much bigger priority for me to focus MoI on the areas where NURBS are actually really easy, pleasant, and quick to use like stuff that can be generated more from 2D drawings.
If you're already familiar with polygon modeling, I'd recommend doing that project using one of those tools instead - basically same as if you were doing highly organic stuff like creature or modeling human faces or things of that nature. When your project does not boil down to recognizable 2D curves that define it well it basically starts to move quite a ways into that organic shape territory, and that's an area where sub-d modeling is much more focused on.
Show messages: All  1  2-8
