Problem with normals at rendering
All  1-3  4-11
4919.4 In reply to 4919.3
Hi Jacobo - I don't have a recent version of Modo over here so I won't be able to test it myself, but hopefully someone who uses MoI and Modo with each other regularly will be able to give it a test and give you some pointers.
Usually you should be able to just export out from MoI, then import into Modo and render though...
The materials that MoI makes by default though do have double sided lighting turned on, is that possibly having some effect on your renders?
In your original screenshot, it almost looks like there is some kind of environment map set up there.
4919.5 In reply to 4919.1
Hi Jacobo - another thing to check is if you're possibly rendering using some render features that have scale sensitive options, like bias factors and what-not to avoid self-shadowing or things like that.
If you are rendering with render features that involve some scale sensitive parameters then check if the imported object's size is fairly different between the different examples you posted.
4919.6 In reply to 4919.5
Ok, I've found the problem, and it doesn't seem to be Moi related. I was using modo 601 instead of 501, and for some reason it caused that. 501 renders it perfectly fine. I don't know if it's a bug or they changed the way normal vertex maps are read. In any case, I'll submit a bug.
Thanks for looking into it!
4919.7 In reply to 4919.6
Hi Jacobo, I'm glad you found out what the issue was! Hopefully it is a bug because LWO vertex normals are already complex enough as it is.
Modo was the first program that used vertex normals out of LWO format but unfortunately they decided to use them in the opposite convention of the rest of the coordinates (something like vertex position coordinates in left hand coordinates and vertex normals in right hand coordinates).
Then later on LightWave 9.6 also supported reading vertex normals out of LWO but they expect a different orientation than Modo. Then for some unknown reason they decided to change it to some other direction in LightWave v 10.
Hopefully Modo is not going to now throw in a 4th different possible orientation for the normals, since the current situation of having 3 different possible orientations to use is confusing enough as it is.
4919.8
Modo 601 has not been released yet, so this must be a beta version? Jacobo's bug report will probably get it fixed before release. Maybe it would be worth passing on Michael's comments to the developers?
EDITED: 13 Feb 2012 by STEVEH
4919.9
Hey Michale and Steve,
It sucks to hear about all the different ways to do that. I wonder why they decided to change it. Hopefully it's a bug and it will get fixed.
I've already submitted it and also asked if it was actually a bug or just a different way or reading those maps. I'll let you know how it turns out.
Thanks!
4919.10 In reply to 4919.9
Hi Jacobo - someone else has written to me that Modo 601 seems to be using the LightWave v10 style orientation for vertex normals.
If you're using MoI v3 there are options for "Modo", "LightWave v9.6", and "LightWave v10" - if you set it to the LightWave v10 style does it then work ok for you in Modo 601.
4919.11 In reply to 4919.10
Hey Michael,
I've just read that on the modo beta forum as well. That's a good thing then. I'm not using v3 unfortunately since I've just started evaluating it so I downloaded v2 trial version, but it's good enough to know that it won't be a problem.
Thanks for letting me know!
Show messages: All  1-3  4-11
