Help with flow.
All  1-3  4-7
4885.4 In reply to 4885.3
Thanks, Michael and bemfarmer
bemfarmer, I saw you post on the way into work, (I have an 50min train trip, so I do a bit of modelling on the train), set up has you suggested and then realized I only have a trial of V2 ,no Flow :(
At home I have a OSX, I have to wait till I get home.
when I realized I did not have V3, I played a bit with curve-projection, realized I might be able to do what I wanted with , curve -> project then an extrude . just have to workout how to add a endcap.... But flow looks miles easier and could be the right solution for a few other models Im working on :)
4885.5 In reply to 4885.4
Hi Steve,
For that method, it's usually best to actually make a cap surface first, which you do by using Trim. Then once you have a small surface piece that has the outline you need you can then use Extrude on that surface to build the solid, or you can use Shell too.
See this previous post for an example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4791.13
4885.6 In reply to 4885.5
cool, more things to try on the way home tonight ;)
4885.7 In reply to 4885.5
Hi Michael
Cool, that trim works, what I did has a test, I used Curve-project to project some letter onto shield, then extruded them, then hide them, then I used trim on the projected curve to cut out end cap, brought back the extruded letter, then fitted the end cap, joined them up, then joined them back to the shield. all back to a solid :)
cheers, steve
Show messages: All  1-3  4-7
