3dm2DXF converter options?
All  1-5  6-8
4884.6 In reply to 4884.5
Michael,
The only way I can import 3D object in that program is via an STL file or via a heightmap kind of image.
As for 2D drawings it's only via the DXF importer. Though it can read 2D splines elements, a circle becomes a kind of an incorrect rounded rectangle and a rectangle become some weird form. I tested creating line, polys, circles and arcs with a simple 2D cad program (QCad) and beside a circle becoming an ellipse and having unconnected lines segments it's usable but QCad doesn't read in spline elements correctly either.
I though I'd try to rebuild every thing with lots of control points and though the various shape look much better now they are still incorrect. I guess my best option for now is to create my 2D dxf file directly in QCad.
Don't worry, I'll find a way.
Felix
4884.7 In reply to 4884.6
Hi Felix,
That probably means it has a bug where it does not read the "weight" values of the spline properly.
NURBS curves are made of a control polygon hull where each point of the hull has both x,y,z coordinates as well as a weight value.
For simple freeform curves the weight values all have a value of 1 and have no effect - but for conic section curves like an exact circle the weight values do come into play and if they are just ignored instead of properly read in then you would get a result that looks like a kind of rounded rectangle rather than an exact circle.
If you use the Rebuild command in MoI that will fit a new freeform curve through the circle and the new freeform curve does not use weights, so using Rebuild could help to avoid this particular problem with the other importer.
Hmmm, that's kind of surprising since that should not involve any weights. I guess it is possible that they also don't pay attention to the degree value and think that everything is degree 3 like a freeform bendy curve usually is - lines are actually degree 1.
I guess if you use Rebuild on these with # of points mode, with at least 4 points for each segment, that will rebuild those lines as degree 3 curves and maybe that will match what the importer seems to be hard coded to use...
It sounds like there may be several different kinds of bugs in their importer though.
4884.8 In reply to 4884.7
Sorry Michael for the long delay.
I tried rebuilding the curve, line and whatever with a large number of control points, the result is a bit better, less distorsion but still far from exact. I know it's not Moi fault as the same unrebuilt files import nicely in other programs I have. I've found a solution via an intermediate program.
You wouldn't believe how much I had to paid for that piece of trash, it's a shame.
Felix
Show messages: All  1-5  6-8
