MoI has detected an unexpected condition (non-fatal).
All  1-2  3-7
4882.3 In reply to 4882.2
Oh, I did hit the report button, but nothing happened...
I figured it must be sending some data over the internet to you automatically?
(nothing popped up or anything)
Where can I find this dump file?
-EDIT-
Ah, found the 5 dump files :P
Sent to moi@moi3d.com
4882.4 In reply to 4882.3
Hi NightCabbage,
No it just tries to open up an e-mail (which you will then have to hit "send" on to actually send to me) but if you use something like web mail instead of outlook then it won't be able to do it.
They'll be moi_report1.zip , moi_report2.zip etc ... files in either the same folder as moi.exe if you can write to there or if you're on Windows Vista or 7 with UAC turned on it prohibits writing to the \Program Files folder so it will instead put them in your Temp folder, go to Start > Run and put in %TMP% to go to there.
4882.5 In reply to 4882.3
Ok - got them in e-mail, thanks!
4882.6 In reply to 4882.3
Hi NightCabbage - ok so that assert is actually in the point picker and it had to do with a problem in intersection object snap.
It's actually fixed though in the second v3 beta - it looks like you're still on the first v3 beta release?
If you get the latest one then that problem should be fixed, you can get it from here:
http://moi3d.com/beta.htm
4882.7
Ah, yes, I am running the Aug-24-2011 beta - didn't know there was one released in October!
Thanks :D
Show messages: All  1-2  3-7
