Real names and Flipping Part 2
All  1  2
4852.2 In reply to 4852.1
Hi Ironice,
> is there any option to export step objects with its real name?
> Left side is exported from Rhino, right side is exported from
> MoI, both as FBX in SI.
Object names are not currently exported to FBX format, I do want to tune that up in the future though.
But object names are exported to OBJ or LWO formats, and OBJ format should work well for going into SoftImage - try exporting out of MoI using OBJ format rather than FBX.
> second: Flipping part 2. I dont know if its a MoI bug....
> The command "flip" is not working with this object.
> Left one is exported with "N-gone" (bad), right one is exported
> with "Quads & Triangles" (good).
Looks like probably a bug in SI's n-gon triangulation - in order to display an n-gon it still has to be converted into triangles and it looks like SI's triangulation mechanism did not process that one n-gon very well. That's not too unusual for there to be occasional n-gon triangulation problems in rendering programs.
If you see a proper result when you export using quads & triangles out from MoI, then that means that you're using MoI's triangulation mechanism instead.
Show messages: All  1  2
