ugly creases in network
All  1-8  9-14
4844.9 In reply to 4844.8
Hi Niko, yup I wrote some about that previously:
quote:
It looks like you may be getting a little bit of wiggling in the curve refitting mechanism as well in this particular case - I'm hoping to do some work in v3 to try and reduce that.
It seems to be a little bit of wiggling that's happening in the curve refitting mechanism when it's processing some of your particular shapes here.
Since Rhino's fitter is working better for this particular curve network that you've got here, why not just use Rhino for building this particular Network instead of MoI, wouldn't that solve your problem?
4844.10 In reply to 4844.8
Hi Niko,
> In Rhino, comparing the wireframes side by side I can also see
> how much cleaner the rhino solution is. IMO the sharp edges still
> show as expected and the surface is smooth where its suppose
> to be. I cannot imagine an example where the MOI solution would
> be more favorable...
I've attached here a simple example where the Rhino solution is not favorable, if you select all the curves and run Network MoI respects the creases and generates the proper output:
Take particular note of the corner areas here:
Now load the 3DM file into Rhino and construct the network there by selecting all the curves and running NetworkSrf. If you examine the same corner areas:
You can see there where the network does not adhere to the corner shape, it makes a smooth surface through there instead of actually coming to a sharp corner. That means that for example if you tried to extrude the bottom shape downwards and then join the extrusion and the upper part, they won't join together properly because the top part kind of bulges away from the sharp corner.
You get similar problems in Rhino trying to use any kind of creased curve to build a big network.
4844.11 In reply to 4844.9
Because I love MOI so much that I want it to be my exclusive nurbs modeler .
I don't know what wiggling is, but will that particular network solve closer to Rhino after you work on what you said?
Thanx
4844.12 In reply to 4844.8
Hi niko, attached here are few other examples to help explain the problem with just trying to ignore creases, try loading these 3DM files into MoI and into Rhino and do NetworkSrf in each.
In MoI you get this result:
And in Rhino take a look at what happens to the corner areas:
Anyway, I hope that gives you some better idea about that issue.
4844.13 In reply to 4844.11
Hi Niko,
> you said?
I hope so, but it's hard to know for sure until after it's actually done.
You also might try using MoI v2 for this one instead of the v3 beta - one change in v3 is that it uses a tighter fitting tolerance for rebuilding the curves, but that can have some side effects like this.
That's another area that I want to work on during v3 - to be able to have a tighter fitting tolerance only for the outside curves of the network that might need to be joined to other things, and a slightly looser tolerance (which makes a lighter density surface) for the internal curves.
But anyway if you try it in MoI v2 you should probably see a lighter surface generated.
4844.14 In reply to 4844.13
Yes it is lighter and i much much prefer it over v3, but it still generates non-uniform spans and still looks pinched where the surfaces come together . Hopefully your solution will work for V3....
EDITED: 12 Jan 2012 by NICKP100
Show messages: All  1-8  9-14
