ugly creases in network
All  1-10  11-14
4844.11 In reply to 4844.9
Because I love MOI so much that I want it to be my exclusive nurbs modeler .
I don't know what wiggling is, but will that particular network solve closer to Rhino after you work on what you said?
Thanx
4844.12 In reply to 4844.8
Hi niko, attached here are few other examples to help explain the problem with just trying to ignore creases, try loading these 3DM files into MoI and into Rhino and do NetworkSrf in each.
In MoI you get this result:
And in Rhino take a look at what happens to the corner areas:
Anyway, I hope that gives you some better idea about that issue.
4844.13 In reply to 4844.11
Hi Niko,
> you said?
I hope so, but it's hard to know for sure until after it's actually done.
You also might try using MoI v2 for this one instead of the v3 beta - one change in v3 is that it uses a tighter fitting tolerance for rebuilding the curves, but that can have some side effects like this.
That's another area that I want to work on during v3 - to be able to have a tighter fitting tolerance only for the outside curves of the network that might need to be joined to other things, and a slightly looser tolerance (which makes a lighter density surface) for the internal curves.
But anyway if you try it in MoI v2 you should probably see a lighter surface generated.
4844.14 In reply to 4844.13
Yes it is lighter and i much much prefer it over v3, but it still generates non-uniform spans and still looks pinched where the surfaces come together . Hopefully your solution will work for V3....
EDITED: 12 Jan 2012 by NICKP100
Show messages: All  1-10  11-14
