3dmCurves2DXF not working with 'MoI 3.0 beta Oct-25-2011' created files
 1-12  13-21
4840.13
Thanks Michael,
I’ve now understood the purpose of the converter. Yes, there are lot of solids and surfaces in the drawings. Overall then it would seem that I cannot export my model.
I was just looking for a way to import a 3DM file to DraftSlight in order to layout plan, elevations and some isometric views with a template.
In particular I was requested to show a wireframe view of the object and in MOI I could not find a way to do it, whence my issue. Importing the dwf could have been a solution.
Has someone came across the same problem and found a solution without recurring to commercial software (if not at least affordable software)? Thanks.
Matteo
4840.14 In reply to 4840.13
Hi Matteo - if all you need is a wireframe and not an actual hidden line drawing, then you can duplicate all the edges of your solids into curve objects, then they would get processed by that converter program.
In order to duplicate them you need to select the edges, then use Copy (Ctrl+C) which puts them on to the clipboard as curves, then use Paste (Ctrl+V) to paste them into the current model. Keep in mind that this will produce a bunch of duplicated geometry.
The easiest way to select all edges is to use the Scene browser and go to the Types section, there is an entry there for "Edges" which you can use to target all edges and select them.
4840.15 In reply to 4840.13
Google Sketch can import dxf
take the version 6 it's free
http://www.brothersoft.com/downloads/sketchup.html
or you can also export directly from Moi in skp format (sketchup)
And inside sketchup ask to show only structure (SelectionToy by Thomthom)
http://forums.sketchucation.com/viewtopic.php?t=14975
4840.16
Thanks Michael,
I tried and it works, only problem I need an hidden line drawing otherwise to messy. However, I found it a useful tip.
Thank you Frenchy as well, I am sure with Sketch Up is going to works, not sure about the free use of the software for commercial purpose, there is an endless debate on the web.
4840.17 In reply to 4840.16
Hi Matteo, I do plan on working on a hidden-line drawing mechanism for MoI but currently you would need to use some other software to generate that for you.
One pretty inexpensive option for doing that is ViaCAD:
http://www.punchcad.com/c-12-consumer-cad.aspx
4840.18
Hi Michael, looking forward for the hidden-line drawing mechanism.
Thanks for the link, very good price and also it also serve my purpose with the layout/template. I will have a look at that. Thank you again.
4840.19 In reply to 4840.16
< not sure about the free use of the software for commercial purpose,
of course the free version of Sktechup is not for commercial use ;)
4840.20 In reply to 4840.19
I think Sketchup Free version is licensed for commercial work.
http://forums.sketchucation.com/viewtopic.php?f=79&t=20842&p=175544&hilit=eula#p175544
4840.21 In reply to 4840.20
not sure that was in 2009 ;)
Now it's
Google SketchUp
Home/Personal Use
Google SketchUp Pro
Professional Use
look the story ;)
https://groups.google.com/a/googleproductforums.com/forum/#!category-topic/sketchup/sketchup/nZl7g5rKW-0
Show messages:  1-12  13-21
