Train Body test
All  1  2-4
484.2 In reply to 484.1
Looks like a good start Mike!
> but it took me a couple tries to get the objects to use as booleans to be solid objects.
Could you describe a little bit more about the problems you ran into for this part?
Did you have some operations generate open surfaces instead of solids in an unexpected way?
484.3
thanks Michael!
Um, I should have stated the problems I was having was due to me not being familiar with the tools.
When I wanted to get circuits, or lines that conformed to the surface of the train,
I used the technique of boolean difference from the surface of the train, copied the resulting lines and then undo the boolean.
then past the lines back into the project.
Then I used the loft and sweep tools to create a solid object to create the windows.
It took me a few tries to get the loft and sweep tools to work "in my head".
Thats what I was saying....
Very pleasant experience thus far Michael!
Mike Fitz
www.3dartz.com
484.4 In reply to 484.3
Well, I'm still pretty interested to hear about any kind of difficulties, regardless of where it originates from... :)
Sooner or later there should be a type of "create curves of intersection" command that would let you do this in a more straightforward way.
That's good! :)
Show messages: All  1  2-4
