Question regarding MoI's conic section abilities
 1-4  5-24  25-32
4835.25 In reply to 4835.24
Hi Anthony,
> and yes by real life i mean make an approximate sketch with paper
> and some sort of drafting tools. what i'm really curious about is how
> a draftsmen would have went about this in the 1950's and if that
> method would work in moi. again, only out of curiosity, not to
> implement for daily use in moi.
I guess check out "The Draftsman's method" that's described here:
http://www.uwgb.edu/dutchs/MATHALGO/Ellipses.HTM
Seems to be an approximation based on sampling several points and then I guess connecting them with line segments - you can repeat the same steps in MoI if you want, but the result will be a polyline approximation of an ellipse and the approximation will be kind of rough as far as CAD accuracy goes.
An approximated sketch on paper is a lot different kind of a thing than actual geometry that you then want to use directly as a basis for further 3D construction in MoI.
> i have found several sketching methods for real life, and of
> course many equations to calculate points. i'm most curious
> if you can use lines and arcs to approximate an ellipse, possibly
> the five center method.
The five center method is described there as well, I was not familiar with it. Since it involves drawing circles, lines, and arcs and finding intersection points I think you should be able to repeat the process in MoI. The result will however be again by CAD standards a pretty rough approximation, probably without a known error bound, and will again be a segmented series of curves rather than just one smooth curve.
It would not be desirable to use a segmented approximation like that as the generator for further 3D shapes, because extrusions and stuff like that which you construct off of it will inherit the segmentation and inaccuracies as well.
So although you could use one of those old drafting methods for constructing some approximation of an ellipse in MoI, it would be a kind of pointless exercise since it would not work well to use the result for much of anything after that.
Meanwhile using one of the ellipse tools generates a mathematically exact ellipse that's made up of just a single totally smooth segment, with a lot less effort involved as well.
So I do not see how one of those methods would be very practical for use in MoI.
4835.26 In reply to 4835.25
hi michael,
i agree with you 100%. i have narrowed this down to the draftsmen method, that you mentioned, as well. i'll let you know if i get this to work out and post a pic of it. i have ruled out the other methods mentioned.
if the draftsmen method works out, and you intended to have an elliptical leading edge, you should be able to define the ellipse by its length and width. the moi ellipse tool could easily generate the ellipse with that info. i just need to see if i can make that ellipse with the draftsmen method.
thanks for the suggestions
4835.27 In reply to 4835.26
Hi Anthony,
I appreciate you're not UK based, however perhaps this might be of passing interest to someone.
The London Science Museum's permanent Mathematics exhibition http://www.sciencemuseum.org.uk/visitmuseum/galleries/mathematics.aspx has a collection of truly beautiful mechanical drawing instruments dating back 190+ years. I highly recommend a visit to anyone with even a passing interest in the history of technical drawing. My recent visit really put into perspective for me just how far we've come in 200 years. Actually, what really did it, and still makes the hairs on the back of my neck stand on end just thinking about it, was being able to touch Stephenson's 'Rocket', built in 1829 in the same room as look inside the actual Apollo 10 capsule!
Back to Earth now, here's a couple of London Science Museum links showing instruments for drawing ellipses. One is an ellipsograph from 1817, the other a trammel from 1876.
http://www.sciencemuseum.org.uk/objects/mathematics/1909-191.aspx
http://www.sciencemuseum.org.uk/images/I032/10302774.aspx
There's also quite a nice animation of a trammel here:
http://en.wikipedia.org/wiki/Trammel_of_Archimedes
Cheers,
Hamish
4835.28 In reply to 4835.27
hi hamish,
i didn't know trammel's really existed, really neat:
http://www.sciencemuseum.org.uk/objects/mathematics/1876-662.aspx
this tool is awesome too:
i remember playing with these as a kid:
http://www.sciencemuseum.org.uk/objects/mathematics/1976-61.aspx
thanks for the links, awesome.
4835.29
hi,
here is an example of the draftmen's method. the results are pretty typical of what I have gotten trying some of the other methods. they just don't seem to work. i could be doing something wrong. but it seems the error is quite large. if i have done everything right, that would leave some of the mechanical drawing tools in the previous link as the only way to draw an ellipse accurately in real life. i imagine you could still define the ellipse by its height and width and that definition could be used by the mechanical tools and cad programs such as moi.
4835.30 In reply to 4835.29
Hi Anthony, from what I can see that you have drawn there, it looks like you are not using "The Draftsman's Method" as described in that previous link (http://www.uwgb.edu/dutchs/MATHALGO/Ellipses.HTM) but rather the "Five-Center Method", is that correct?
The page there mentions the following:
quote:
"The true ellipse is shown in red, the approximation in purple. The approximation is quite good for slightly or moderately eccentric ellipses but becomes obviously incorrect for very elongated ellipses."
So yes as far as I can tell that method produces a pretty rough approximation which gets worse as the width to height ratio increases.
An ellipse is a continuously changing curve and you simply cannot make a very good approximation of a rather elongated one using only a couple of arc pieces...
4835.31
Just to follow up on this and out of pure curiosity I made an ellipse in NX and simplified it, NX has a tool which can simplify splines into true lines and arcs to the closest approximation.
Anyway, NX simplified a 100mm x 50mm ellipse into 28 arcs.
4835.32 In reply to 4835.31
thanks guys, i would have to agree. the pictures are of the draftmen's method. however i tried a bunch of methods and nothing seemed to come close. in their examples they show good agreement. but with the ellipse i have, i don't get good agreement.
the example ellipse i'm working with has the following characteristics:
the height from center is 9.5313263 mm, the width from center is 3.5668193 mm, the foci from center is 8.8387771 mm, and the rho value of the conic section the ellipse started from is 0.4632322 mm.
at this point i'm assuming that if it was the 1950's and i wanted an ellipse with a certain height and width, it would be generated with a special mechanical drawing tool, as shown in previous links.
Show messages:  1-4  5-24  25-32
