Question regarding MoI's conic section abilities
 1-10  11-30  31-32
4835.11 In reply to 4835.10
I knew it was something like that...:o
4835.12 In reply to 4835.9
Hi Anthony,
> that helped a lot. as with burrman, i may be finding it is a
> bit off. not sure yet. is there a way to get the width of the
> ellipse.
Currently there is no way to get the full ellipse major or minor axis width from an ellipse segment.
> i'm trying to use the center snap you pointed out to recreate an ellipse.
What are you using for the orientation of the ellipse? The ellipse segments that are created by the conic command are not restricted to have their major and minor axis only aligned to the world x/y axis directions, the ellipse that it is a part of can be rotated around.
So you've got an orientation and also size in the x and y axis directions that you would need to all be specifying in order to manually draw a new ellipse on top of the existing ellipse segment.
If you are creating en ellipse that shares the same center point but has a different orientation or major/minor axis sizes then that's why they would not match.
> i guess what i'm trying to do right now is confirm the geo
> coming out of the moi conic section tool.
If it has a center point snap then it means that internally MoI has analyzed it and confirmed it to be an exact ellipse segment already...
If you need more confirmation than that, you maybe need to take it into some more specialized software that might give you more detailed mathematical data about the ellipse segment than what MoI is currently set up to show in its UI.
4835.13 In reply to 4835.12
thanks michael,
i think you've explained it. the rotated axis may be the missing link. i can use the center point and eyeball the width and overlay an ellipse. however, it doesn't agree with stevens' method. the rotated axis aspect, may be why. having the width and the center, in the future, may be a useful thing. however, i think my curiosity is satisfied at this point.
thanks
Notes on Conic command, rho, ellipses, and eccentricity.
For a given ellipse, there is one value for the eccentricity.
For a given ellipse, there can be many rho values.
The conic involves two tangent lines.
The tangent lines do not need to be symmetric.
The conic is determined by 3 points plus rho, or 4 points. (start, end, apex, through or rho).
rho = vertex distance from chord center / apex distance from chord center.
rho is rounded off, in MoI, to two decimals. (EDIT Incorrect, see next post) :-)
rho can be calculated by using custom distance.
The maximum positive rho value is 1 for a conic.
For a hyperbola, 0.5 < rho <= 1.
For a parabola, rho = 0.5.
For an ellipse, rho < 0.5.
A negative rho has the through point opposite the chord center, from the apex point.
This is a "negative" distance. rho < 0. (examples: rho = -.3, -.6, -1.2, -4.5, -52.0 ...)
When MoI does a conic ellipse, the center point of the ellipse is determined, and can be revealed by drawing a line near to it.
Draw a line from the apex, through the chord center point, to where the center pops up.
Create a line segment from the conic intercept point to the center.
Rotate it 180 degrees, to find the opposite point on the ellipse.
Run conic again, at negative rho, using the opposite point as the through point, to create the whole ellipse.
(rho is also a measure from 0 to 1 of the angle of a plane through a right cone.)
To find the focus, and eccentricity, create a line the length of half the major axis, and rotate it
to the major axis. (from the minor vertex). Eccentricity = f/a.
(So MoI indirectly determines the eccentricity and focus.)
EDITED: 7 Jan 2012 by BEMFARMER
4835.15 In reply to 4835.14
Hi Brian, great notes there - just one clarification on this part:
It's really just the display in the edit field that is rounded to 2 decimals - you can type in a number into that field with as many decimal places as you want and whatever you type will get set as the actual rho value for constructing the conic.
You can also adjust how many decimal places are displayed in edit fields by the setting under Options > General > "Decimal display" , but again that only controls what is displayed, if you type in more decimals than that it will use what you type in any edit field.
4835.16
thanks brian,
that information allowed me to create a whole ellipse which was one of my goals. i used the conic tool to make the first arc as usual. then i mirrored/rotated the arc. then based on what you said i found you could use the conic tool to draw the remaining arc by simply using the ends of the first arc, the tan/tan point of the first arc, and the apex of the mirrored/rotated arc. i didn't need to enter a rho value to do that step. so two simple additional steps to get a full ellipse. you can then confirm the ellipse by using the center width and height.
the only thing i still can't figure out is what information one would need to duplicate the ellipse manually. without any nice computer tools like an ellipse button or a conic section button. i have the center, width, height, and i calculated the foci, and calculate the rho value. but none of that really helped me duplicate the ellipse manually. i keep trying stevens' method but can't get the same ellipse with that method. i guess i'm just curious that if i was a naca engineer back in the day, what info would i need to recreate an elliptical leading edge. i'm also puzzled as to why they define the leading edge with a circle if they were putting ellipses in there (i'll probably never know the answer to that question).
i guess i'm wondering if i could add some sort of simple information into the naca definition that could be used to put an ellipse in manually. i know we don't need it for your script. but i'm just wondering about it in general.
update; i found some equations that could be used. that would satisfy my question about how you could define this, in the old days, without too much difficulty. now the only thing i'm curious about is if i can somehow re-create the ellipse, in moi, without using the ellipse or conic section tool. mainly out of morbid curiosity.
4835.17 In reply to 4835.16
Hi Anthony,
Which tools would you want to use instead?
For a NURBS curve to represent an exact conic section curve involves having not just control point positions of the curve set but also particular weight values for each control point set as well, which the ellipse and conic commands will do.
You can't get a conic section (other than a parabola) by just placing curve x,y,z control points without having weights also set.
If you only want an approximated ellipse rather than an 100% mathematically precise one then that's another matter.
See here for more information on the properties of NURBS curves:
http://en.wikipedia.org/wiki/Non-uniform_rational_B-spline
http://www.mactech.com/articles/develop/issue_25/schneider.html
See the parts that describe what a "rational" curve for more information on weights and what NURBS configurations can yield different conic section curves.
4835.18 In reply to 4835.16
If you could start with a simple arc and know the minor axis of the ellipse, you could just rotate the arc by a distance of the minor axis in an opposing plane, then the ellipse would appear in plane... Also, a 1d scale of the arc would produce the same. (The rotated arc would need to be flattened to the desired plane.
4835.19 In reply to 4835.18
Hi Burr, yup a circle is a conic section curve too, and doing a one directional scale of the circle does produce an ellipse from that.
I'm not sure if drawing a circle was allowed for what Anthony had in mind or not, I'm not really quite sure what he was looking for in creating an ellipse without using the ellipse or conic tools, I thought maybe he meant by making a curve by just placing control points directly?
Anthony - maybe instead of saying which tools you don't want to use to make an ellipse, maybe you could describe which other tools you did want to use to create it?
But of course it's by far the easiest to use the ellipse commands to build an ellipse, that's what they are there for... So I am kind of puzzled by what you're trying to accomplish there.
4835.20 In reply to 4835.19
hey michael,
i replied to your post this morning but i notice its not here now. i was saying that i'm trying to find a definition of an ellipse that works equally well in real life and moi. nothing is wrong with moi, i love the program and the tools to make a conic section and ellipse work great. i'm just curious about defining the ellipse for both real life and moi. the reason being the airfoil i'm working with has the leading edge defined with a circle. however, it seems an ellipse is really what is in there (at least for the data set i am referencing right now). so it made me wonder, if i wanted to define an ellipse, how would i go about that. i recently found something that might help. you can define concentric circles about each foci and where they intersect is the points on the ellipse. this would fit in with the rest of the airfoil definition, which consists of points that you run a spline through. so if you add some points at the leading edge, you could run a spline through those as well. which i believe is what you were talking about before.
i was trying to use the stevens' method, however, haven't had luck with that. the premise there would be to use the line and arc tools to draw the ellipse. i'm open to how to define it. any tool would be fine, so long as you can duplicate the method in real life. back when these airfoils were created, it was done on drafting tables with slide rules and things. no calculators or computers.
hope that clears up any confusion i caused you. her are some links to interesting info about the topic:
http://demonstrations.wolfram.com/CirclesAndEllipses/ - interesting way to graphically find x,y points along the ellipse
http://en.wikipedia.org/wiki/Hypotrochoid - interesting and simple way to draw an ellipse, also simple equations to use
http://en.wikipedia.org/wiki/Ellipse - has some equations you can use to calculate points easily, i like the polar coordinates in particular
4835.21 In reply to 4835.20
Please delete semicolons from links... :-)
4835.22 In reply to 4835.21
thanks brian,
didn't notice that.
4835.23 In reply to 4835.20
Hi Anthony,
Well, an ellipse is sort of a mathematical concept - you can't actually create an actual 100% exact one in real life, stuff like the paper you use is not 100% flat but has little tiny bumps in it, if you draw it with a pen it won't have 0 width like an actual true ellipse, etc, etc...
Do you mean a method to make a sketch representation of an ellipse in real life just using a pencil and paper?
Some kinds of pencil and paper sketch methods can translate well into MoI when they involve stuff like drawing some auxilary shapes and finding intersections between them for where to start new lines at and stuff like that.
But an ellipse is a continuously changing curve, it's a lot different than drawing a line - methods that involve some kind of continuous change applied to the pencil won't really have a very good direct equivalent in MoI. I guess you could try using the Sketch command to do a brush stroke type approximation, but it will be really difficult to get a high quality approximation without wiggles in it - meanwhile if you use the actual ellipse or conic drawing tools you get a super precise ellipse.
I guess if you were really intent on simulating a pencil or pen draw method you could write a script that basically drew a curve that was plotted with a whole lot of control points in it. If you've seen some of the function curve plotting commands that Brian has posted earlier, that's how those were made. But I really can't see how that would be of any benefit for the case of an ellipse though, since with NURBS an ellipse does not have to be approximated it can be formed exactly instead which is what the ellipse and conic commands do.
One of the sketch based ways for drawing an ellipse is to put 2 pins in at the foci points and then have a length of string between them, then if you hold the string taut with a pencil and drag it, it will trace a sketch of an ellipse. That's again though the kind of continuously changing pencil stroke type operation that doesn't really translate very well into MoI as a construction technique.
If you wanted to define an ellipse mathematically instead of by some kind of "pencil sketching with apparatus" method then that would translate more directly into MoI's ellipse or conic drawing commands though...
Again though, I'm still not entirely sure if I completely understand what you're looking for. Just in general in the more abstract environment of CAD systems you can't necessarily use drawing methods that involve some kinds of physical processes like tension or friction with various moving parts and apparatus or stuff like that... But on the other hand with CAD you are more free to make exact mathematically defined stuff more directly instead of trying to simulate them with physical processes....
EDITED: 8 Jan 2012 by MICHAEL GIBSON
4835.24 In reply to 4835.23
hi michael,
"Do you mean a method to make a sketch representation of an ellipse in real life just using a pencil and paper?" yes that's what i mean
"Some kinds of pencil and paper sketch methods can translate well into MoI when they involve stuff like drawing some auxilary shapes and finding intersections between them for where to start new lines at and stuff like that." yes this is what i'm trying to do at the moment
i have been able to add points and run a spline through them. i wasn't too fond of that method however. when you make a solid, using this method, it comes out all lumpy.
as i mentioned, moi is working fine. the ellipse tools you have are great. brian already made a script to solve the main problem, using the moi conic tool. i'm just curious about trying to see if there is a simple way to define and draw an ellipse in real life and with moi. and yes by real life i mean make an approximate sketch with paper and some sort of drafting tools. what i'm really curious about is how a draftsmen would have went about this in the 1950's and if that method would work in moi. again, only out of curiosity, not to implement for daily use in moi.
i have found several sketching methods for real life, and of course many equations to calculate points. i'm most curious if you can use lines and arcs to approximate an ellipse, possibly the five center method.
please don't spend any more time on this. i know you have more important things to do. i will figure it out eventually. you helped me find the center of an ellipse created with the moi conic section tool. brian helped me create the whole ellipse using the conic section tool and mirror/rotate. with that added information, i could confirm the ellipse created with the conic section tool to that of one created with the ellipse tool. now i'm just learning.
4835.25 In reply to 4835.24
Hi Anthony,
I guess check out "The Draftsman's method" that's described here:
http://www.uwgb.edu/dutchs/MATHALGO/Ellipses.HTM
Seems to be an approximation based on sampling several points and then I guess connecting them with line segments - you can repeat the same steps in MoI if you want, but the result will be a polyline approximation of an ellipse and the approximation will be kind of rough as far as CAD accuracy goes.
An approximated sketch on paper is a lot different kind of a thing than actual geometry that you then want to use directly as a basis for further 3D construction in MoI.
The five center method is described there as well, I was not familiar with it. Since it involves drawing circles, lines, and arcs and finding intersection points I think you should be able to repeat the process in MoI. The result will however be again by CAD standards a pretty rough approximation, probably without a known error bound, and will again be a segmented series of curves rather than just one smooth curve.
It would not be desirable to use a segmented approximation like that as the generator for further 3D shapes, because extrusions and stuff like that which you construct off of it will inherit the segmentation and inaccuracies as well.
So although you could use one of those old drafting methods for constructing some approximation of an ellipse in MoI, it would be a kind of pointless exercise since it would not work well to use the result for much of anything after that.
Meanwhile using one of the ellipse tools generates a mathematically exact ellipse that's made up of just a single totally smooth segment, with a lot less effort involved as well.
So I do not see how one of those methods would be very practical for use in MoI.
4835.26 In reply to 4835.25
hi michael,
i agree with you 100%. i have narrowed this down to the draftsmen method, that you mentioned, as well. i'll let you know if i get this to work out and post a pic of it. i have ruled out the other methods mentioned.
if the draftsmen method works out, and you intended to have an elliptical leading edge, you should be able to define the ellipse by its length and width. the moi ellipse tool could easily generate the ellipse with that info. i just need to see if i can make that ellipse with the draftsmen method.
thanks for the suggestions
4835.27 In reply to 4835.26
Hi Anthony,
I appreciate you're not UK based, however perhaps this might be of passing interest to someone.
The London Science Museum's permanent Mathematics exhibition http://www.sciencemuseum.org.uk/visitmuseum/galleries/mathematics.aspx has a collection of truly beautiful mechanical drawing instruments dating back 190+ years. I highly recommend a visit to anyone with even a passing interest in the history of technical drawing. My recent visit really put into perspective for me just how far we've come in 200 years. Actually, what really did it, and still makes the hairs on the back of my neck stand on end just thinking about it, was being able to touch Stephenson's 'Rocket', built in 1829 in the same room as look inside the actual Apollo 10 capsule!
Back to Earth now, here's a couple of London Science Museum links showing instruments for drawing ellipses. One is an ellipsograph from 1817, the other a trammel from 1876.
http://www.sciencemuseum.org.uk/objects/mathematics/1909-191.aspx
http://www.sciencemuseum.org.uk/images/I032/10302774.aspx
There's also quite a nice animation of a trammel here:
http://en.wikipedia.org/wiki/Trammel_of_Archimedes
Cheers,
Hamish
4835.28 In reply to 4835.27
hi hamish,
i didn't know trammel's really existed, really neat:
http://www.sciencemuseum.org.uk/objects/mathematics/1876-662.aspx
this tool is awesome too:
i remember playing with these as a kid:
http://www.sciencemuseum.org.uk/objects/mathematics/1976-61.aspx
thanks for the links, awesome.
4835.29
hi,
here is an example of the draftmen's method. the results are pretty typical of what I have gotten trying some of the other methods. they just don't seem to work. i could be doing something wrong. but it seems the error is quite large. if i have done everything right, that would leave some of the mechanical drawing tools in the previous link as the only way to draw an ellipse accurately in real life. i imagine you could still define the ellipse by its height and width and that definition could be used by the mechanical tools and cad programs such as moi.
4835.30 In reply to 4835.29
Hi Anthony, from what I can see that you have drawn there, it looks like you are not using "The Draftsman's Method" as described in that previous link (http://www.uwgb.edu/dutchs/MATHALGO/Ellipses.HTM) but rather the "Five-Center Method", is that correct?
The page there mentions the following:
quote:
"The true ellipse is shown in red, the approximation in purple. The approximation is quite good for slightly or moderately eccentric ellipses but becomes obviously incorrect for very elongated ellipses."
So yes as far as I can tell that method produces a pretty rough approximation which gets worse as the width to height ratio increases.
An ellipse is a continuously changing curve and you simply cannot make a very good approximation of a rather elongated one using only a couple of arc pieces...
Show messages:  1-10  11-30  31-32
