Reverse engeneering the manual way....
All  1-3  4-9
4829.4
Sometimes its best to import a poly object and simply "trace" it in 3D.
4829.5 In reply to 4829.4
I was thinking along the lines of Michael's Obj23dmWireframe converter script. That way you get all the edges brought in as curves. You can then construct nurbs surfaces based on those curves.
4829.6 In reply to 4829.5
What puzzles me a bit is if you have made then surface patches, for example, you would not have surface continuity, right? Would then when joining the surfaces to a solid and filleting the edges give you about the same result, as for example a Tspline converted mesh?
4829.7 In reply to 4829.6
Hi Stefan,
> continuity, right?
The way those reverse engineering tools build the patches, the adjacent patches have knowledge of each other and are adjusted to be smooth with each other where they meet up, they're not actually built totally separately from each other.
No, not really - putting in fillets tends to be a different kind of a shape. A Tspline converted mesh has a more sort of overall uniform kind of melting and smoothing going on.
4829.8 In reply to 4829.7
ah, i understand now. Thanks for the information!
4829.9
Thank you Michael for your imput !
Peter
Show messages: All  1-3  4-9
