Constructing a simple fuselage
All  1-16  17-19
4821.17 In reply to 4821.15
Hi Steve, yeah Burr means select the output surface and then turn on the surface control points, not turn on control points for the input curves.
If you want to experiement with that method for deforming the surface, you'll need to either delete the end caps of the revolve or turn off the "Cap ends" option when creating it so that you've got just one surface instead of something with multiple surfaces joined together, and then you'll be able to turn on its surface control points.
Also if you want to try that method, it may work better if you create a regular symmetrical revolve to start with instead of a rail revolve - a regular symmetrical revolve will get converted to a fully squishy surface by a kind of internal surface rebuild if you start pulling some of its control points around.
4821.18 In reply to 4821.17
Wow I didn't know that, thanks guys
I have a play around tomorrow
Is this unique only to revolve?
Steve
4821.19 In reply to 4821.18
Hi Steve,
Well, you can turn on surface control points for any surface object - but not if you've got an object made up of multiple trimmed surfaces that are joined together. When you've got an object like that it will not show control points because it would be too easy to pull them apart and make their joined edge not touching anymore. There's some information on this in the FAQ here:
http://moi3d.com/faq#Q:_Why_does_show_points_work_for_some_objects_but_not_others.3F
But if you get any surface down so that it's just 1 single surface all by itself (either delete other pieces, or use Edit > Separate) and not joined to anything else, then you can turn on surface control points for any individual surface like that.
Show messages: All  1-16  17-19
