Just a test :)
All  1-6  7-10
482.7 In reply to 482.6
Thx for the advices
Don't understand why for you the last image don't stay until to press the button??? (works for me perfectly)
For size I had reduced the size but the resultant file didn't reproduced that :(
Surlely something I have not enable ??
For this time I have made a PDF file (1.1 megas zipped so more heavy than a swf)
Movement of the cursor is not keep by this format
Pressed button works fine
Tell me if the Screen is visible this time for a latop 17 inch
Pdf exo
482.8 In reply to 482.7
..it's my mistake about the last frame not staying on the screen.. I think what happened is yesterday, I opened the .swf before I
extracted it from the zip file, so it was extracting frame by frame which made it unstable...sorry for the confusion.
In the PDF the size is good for my screen.
-jesse
482.9 In reply to 482.8
> it's my mistake
:) So I have not to make an headache for search the bug :D
Here a new test about the Import Image as Model in Moi :) (2 Megas)
Unzip and Load in your navigator the "Guitare.Html" file who must launch the "Flash" file at the good size
Tell me if that is visible on a Latop 17 inch (you can use F11 / Full Screen/Normal) Screen
Made with the free crazzy Wink :)"
EDITED: 25 Mar 2007 by PILOU
482.10 In reply to 482.9
Thanks for the suggestion of using F11. I have a wide screen but it's not tall,
so that helped. ;-) I like your use of the arrow keys instead of a timed transition
between frames.
Wink is pretty cool!
-jdk-
Show messages: All  1-6  7-10
