Just a test :)
All  1-5  6-10
482.6 In reply to 482.5
It's looking good so far, if I may offer a suggestion..:-)
The last frame that shows the results after the Boolean
did not always stay on the screen long enough to see it..
at first, then it worked sometimes... I'm not sure why it was like that.
In the Properties up on the top right area of the interface,
there's place to tell Wink to stay in the frame for X amount
of seconds. The animated cursor travel of Wink can make
it look like there is movement using a considerably lower
number of frames than what you initially record, so by
deleting similar frames in between the "action"
and by giving the frames that show the significant changes from
one operation to another, a certain amount of time to
stay on the screen, you can cut down the file size of the swf
without any loss of smoothness to the animation.
hope it makes sense. :-)
Jesse
P.S. Viewing it on a 17 inch laptop screen I had to scroll down
to find the green arrows and scroll back up to see the movie,
so if you down-size MoI to 750 x 500 or so, to make a smaller
image frame, it will fit on the screen better.
EDITED: 24 Mar 2007 by JESSE
482.7 In reply to 482.6
Thx for the advices
Don't understand why for you the last image don't stay until to press the button??? (works for me perfectly)
For size I had reduced the size but the resultant file didn't reproduced that :(
Surlely something I have not enable ??
For this time I have made a PDF file (1.1 megas zipped so more heavy than a swf)
Movement of the cursor is not keep by this format
Pressed button works fine
Tell me if the Screen is visible this time for a latop 17 inch
Pdf exo
482.8 In reply to 482.7
..it's my mistake about the last frame not staying on the screen.. I think what happened is yesterday, I opened the .swf before I
extracted it from the zip file, so it was extracting frame by frame which made it unstable...sorry for the confusion.
In the PDF the size is good for my screen.
-jesse
482.9 In reply to 482.8
> it's my mistake
:) So I have not to make an headache for search the bug :D
Here a new test about the Import Image as Model in Moi :) (2 Megas)
Unzip and Load in your navigator the "Guitare.Html" file who must launch the "Flash" file at the good size
Tell me if that is visible on a Latop 17 inch (you can use F11 / Full Screen/Normal) Screen
Made with the free crazzy Wink :)"
EDITED: 25 Mar 2007 by PILOU
482.10 In reply to 482.9
Thanks for the suggestion of using F11. I have a wide screen but it's not tall,
so that helped. ;-) I like your use of the arrow keys instead of a timed transition
between frames.
Wink is pretty cool!
-jdk-
Show messages: All  1-5  6-10
