Curve selection for Flow
All  1-2  3-5
4814.3 In reply to 4814.2
Here's an example of it happening on my system.. Since you said it works locally for you, I'll trudge around to see if I can figure it out.. Let me know if you have any input that may help me figure it out.
4814.4 In reply to 4814.3
Hi Burr, actually it looks like it is dependent on the "Display hidden lines" option being on or off under the View palette:
I had that turned on, that's probably why it was behaving differently for me.
If you turn it on, does it then work ok for you?
I think there is something that needs tuning up though, probably the edges are overwriting the curve when they should instead be skipped because their parent object has selection lock on it. Selection is such a complex mechanism...
4814.5 In reply to 4814.4
Ahhh, Genious! That was it.
Show messages: All  1-2  3-5
