Bending Object ?
All  1-5  6-9
4813.6 In reply to 4813.5
Hi Anis - it does not seem very likely to me that MoI would get those particular features in the future. Those kinds of features take a long time to develop, and the geometry library that MoI currently uses does not have any focus in that particular area of work.
Stuff like that usually requires licensing a kernel like ACIS or Parasolid that have been building up the feature set for those areas for a long time already.
Sheet metal design is just in general a big area that I don't really have much experience in - that's another reason why it is unlikely that features for that specific area will be coming to MoI. If you need to do that kind of sheet metal design you should focus on using one of those programs that are more oriented towards it currently.
4813.7 In reply to 4813.6
Hi Michael...
I understand the situation, no problem... I am just curious the future of MoI :).
It will interesting to see what is the next new feature coming to Moi after you finilize the MoI Osx.
Thank you...
4813.8
Sheet metal design packages are very specialised program's using unique calculations specifically used for the sheet metal industry only, it considers the metal used along with values like tensile strength, Young's modulus, yield strength etc, to determine the end result and behaviour of bent or formed metal. So if Michael is considering studying metallurgy then we will probably see it In MoI V7 or when it becomes 'Autodesk MoI' ;)
Merry Chistmas
4813.9 In reply to 4813.8
Hi Danny....
If you see the video on my previous post, you can see Cimatron can bend object easily. Here in MoI I wish to see the same command :). No need to considering material properties. I just need on "modeling" side, no need to have simulation side. For the forming ability then we can use another CAE software. It will nice if MoI can help us on modeling side. Thats what initially I am thinking about.
BTW, is there any similar command in NX ?
And yes..., we hope that MoI not aquired by Autodesk :(.
Thank you...
Show messages: All  1-5  6-9
