Network surface
 1-9  …  30-49  50-69  70-89  90-91
481.70 In reply to 481.66
This is some great stuff! Exactly what I was wishing for while making my most recent model. I'm really looking forward to the next beta...
Thx for these extra precisions !
Seems the "scaling curve" is the dead of the classic way of the sweep :)
EDITED: 26 Mar 2007 by PILOU
481.72
Wow!
Hi Micheal, i found MOI a few day ago and i must say it's absolutly awesome!!
When i think how fast it is possible to model complex objects, i can't imagine that.
right now i try to use MOI for some complex objects. The Boole-function is great!
Absolutly perfect mesh. No bugs in the mesh. Dreamy! The Fillet-function.
Ever wanted to have something like this.
This is a scrennshot from my first serious try.
I need it for things like this:
(not done with moi, done with Cinema and renderd with FinalRender2)
And i think in the future i will need it for nearly everything. :-)
Do you know what we'll have to pay for it when it's ready?
Janne
Found MOI, LOVE MOI, will buy MOI
Everything about B-W-Design
EDITED: 11 Apr 2007 by B-W-DESIGN
481.73
Very nice work !!!!!!
***There is always a better way to do things... Just find your Moment of Inspiration***
481.74 In reply to 481.72
Hi Janne, that's a fantastic result from your first serious try!
Those are also some great renderings and models that you've done in Cinema4D - so much detail! It looks like MoI should be useful for modeling a lot of those pieces.
The high quality n-gon mesh export should make MoI a nice companion to Cinema...
Did you notice that you can do a boolean operation between a solid and a planar curve? I mean for instance if you want to boolean away a circular hole all the way through the object you can just do the boolean using the circle instead of needing to extrude to a cylinder. You'll still need to extrude for cuts that do not go all the way through the object, but for ones going all the way through that can save some time.
It will be around US $200.
I'm glad that you like MoI!
481.75
I agree, those are some seriously impressive results both on the modeling and rendering for your first as you said "serious" try with Moi. This is real nice! :)
Please keep on posting more.
/ Magnus
481.76
Ok, here is the next one.
Just spent 10-15 min. Thats the result. Just played around.
I LOVE Moi.
I will buy Moi.
I just told every body in other forums about moi. Many downloaded and tried it. All of them love it!
A very nice peace of software.
Thanks for all those compliments. :-) Nice to here that.
And thanks for the tip about boole. must try it.
MOI rules!
481.77 In reply to 481.72
Great work, your renderings are also very good!
-Jesse
481.78 In reply to 481.76
This one looks good too! I love seeing the results of just a short period of time spent.
Fabulous clock-making!
Added to the Special thead gallery :)
EDITED: 14 Apr 2007 by PILOU
481.80
Oh, thanks, nice to hear.
But, did you noticed that the clocks-renderings are not made with Moi?
481.81 In reply to 481.72
PLEASE don't say those clock parts are polymodelled :| That would be SICK... Are they?
481.82
Wow, that watch is great! I love the attention to detail, and you put together a very nice looking render.
481.83 In reply to 481.80
< But, did you noticed that the clocks-renderings are not made with Moi?
Yes, and you say it too in your post :)
481.84
Don't panik. I've done most parts with Splines. Only the watchcase is polymodelled.
And here ist a few more clockwork. Here i used completly MOI. Love it. It is so easy to use. And fast!!
Now i think i'am "King Booly" :-)))
[Edit]
Ok, here is a little Rendering with FinalRender.
EDITED: 30 Apr 2007 by B-W-DESIGN
Boolywood indeed ! :)
Added Special Thread Gallery
481.86
This is the viewing in the later coming onlineshop.
There you can configurate your own watch. Hands, belt and so on. Then you get a 360°-turnaround with 8 single frames.
(ok the background will be another.)
481.87 In reply to 481.86
Very nice - super realistic!
481.88 In reply to 481.20
Hi michael,
it would be nice to have some kind of scene tree, or a HUD indicator, that would show which objects are history dependant, and which would allow to select the 'parent' curves for it.
481.89 In reply to 481.88
Hi Moka, this would definitely work well in a scene/object tree type display. But it will take quite a bit of time to develop that so I don't expect to have that until version 2.0.
In the meantime, I'll see if I can add some scripting methods so that it would be possible to set up a keyboard shortcut that will select the parent curves of an object.
Show messages:  1-9  10-29  30-49  50-69  70-89  90-91
