Roof
All  1-3  4-12
4807.4
I want to make a single surface using a kind of overlay to highlight the shadows in rendering and have a quick calculation otherwise the file gets heavier like this that I enclose 440 kbytes
It is not possible with loft, sweep, extrude, or create a series of curves that create a curve in a single moment on which to apply an offset surface ....... a curve that has recesses for the shadows?
4807.5
If you use a polygon modeller for this, like Modo, you could use replicators, which are place holders until actual rendering. This make the model very light. I have created renders with several million polygons using this method (1 billion was the most I managed).
If you do this in nurbs, like Michael says, you really need distinct objects.
4807.6 In reply to 4807.5
Maybe for just "looks", something similar to this:
It's a network.
4807.7 In reply to 4807.6
That looks quite good Burr, and it allows for creating it as a larger "sheet" of stuff.
Will that method work for you Tony?
But really if you're mostly concerned about file size, then using an instancing feature in your rendering program is probably the way you would want to do it - many rendering programs have some way to replicate an object where it does not fully copy each separate one and instead keeps it as a lightweight instance of the main one.
4807.8 In reply to 4807.7
It probably wouldnt texture very well.
4807.9
Exact burrman ..... But the problem is that objects must overlap to see the shadows ..... well I think this is unfortunately the real difficulty.
thanks anyway
4807.10 In reply to 4807.9
Well, you can adjust the curves a bit too:
4807.11 In reply to 4807.10
Had to sample it...
4807.12 In reply to 4807.11
Sure, it was just what I was saying ...... you have been a great help thanks
Hello and thanks
Show messages: All  1-3  4-12
