fillet help
All  1-10  11-19
4802.11
You can also use the Freeware beta Autodesk 123d for extrem Fillets.
Size: 631 KB, Downloaded: 18 times, Dimensions: 1881x1092px
Size: 604.9 KB, Downloaded: 9 times, Dimensions: 1881x1092px
Size: 753.4 KB, Downloaded: 17 times, Dimensions: 1881x1092px
Size: 575.1 KB, Downloaded: 13 times, Dimensions: 1881x1092px
Size: 823.4 KB, Downloaded: 14 times, Dimensions: 1881x1092px
Size: 622.6 KB, Downloaded: 15 times, Dimensions: 1881x1092px
Size: 657.6 KB, Downloaded: 7 times, Dimensions: 1881x1092px
Size: 578.2 KB, Downloaded: 10 times, Dimensions: 1881x1092px
Size: 774.4 KB, Downloaded: 13 times, Dimensions: 1881x1092px
Size: 773.9 KB, Downloaded: 16 times, Dimensions: 1881x1092px
Size: 644.7 KB, Downloaded: 35 times, Dimensions: 1881x1092px
4802.12 In reply to 4802.11
Yes I use that app from time to time myself as well.
Peace,
Rich_Art. ;-)
4802.13
Wow, thats pretty amazing.
4802.14 In reply to 4802.11
thats awesome. what file format did you use to open it in 123d?
4802.15
Moi Export Step or SAT
4802.16 In reply to 4802.15
did you edit the model? I keep getting a fillet failure.
4802.17
Most it`s a Scale problem, when you export "step" in your scene you can try fillet units between 0,1 and 0,005.
Or you can try to edit it with press/pull. Press or pull a patch a little bit: (0,0001).
And Try to Fillet again.
Size: 657.6 KB, Downloaded: 9 times, Dimensions: 1881x1092px
4802.18
4802.19
One thing that helps with fillets, is to avoid unneccessary edges in your construction. I find that when I have built a curve structure, it is often best to join it, then carry out a rebuild on it to make one single curve. The original joined curve will create edges if you, say, extrude it, where the joins were. The rebuilt curve won't.
Show messages: All  1-10  11-19
