Game controller joystick
 1-8  9-28  29-35
4794.29 In reply to 4794.27
Thanx, M-Dynamics, this hard edges was the only thing in your model that I was not sure in. I do not try Mike' method to fillet it, but as you say it looks like impossible.
On the reference image those edges are smooth, so I decided to try if it possible to make it with loft) I tried this method when I saw joystick first time, but unfortunately I could not manege to make this form.
After that I had some experience, and tried to do it again today and I managed to make it. This loft method in this case require a bit experience, to understand how it bends surface. It's more complex than all forms I made before.
Pilou, I'm not sure what do you mean, could you tell it in another words?
4794.30 In reply to 4794.29
At 0.22 inside the video, from what ( a file, ..a photo,.../ and how do you draw these lines ?
4794.31 In reply to 4794.30
I used model as reference, and draw all curves flat.I draw first curve and than duplicated it and tweak. I made it for all curves to make sketch of object. Than I made loft to see what I had, and start to tweak points in all directions, to make object look like refference. I f you mean where I get them from I make it for about 30-40 min so I do not record all process.
4794.32 In reply to 4794.31
Many thanks for the infos!
4794.33 In reply to 4794.32
Welcome)
Portfolio: www.samardac.tumblr.com
4794.34 In reply to 4794.1
Mauro,
Thanks for sharing the model as a gift!
I like the method in your original post here and it's attention to each area as a modeled feature. This would allow various parts to be "de-featured" for the manufacturing process.
Yes, we still need the variable fillet.
Thanks again....
4794.35 In reply to 4794.34
Many thanks Burr !
M
EDITED: 19 Dec 2021 by M-DYNAMICS
Show messages:  1-8  9-28  29-35
