Setting line width of individual lines and a bug
All  1  2-5
4786.2 In reply to 4786.1
Hi Martin, no there's not currently any way to set line width differently on individual objects. That is something that I want to add in the future though.
> By the way if I use moi.view.lineWidth -= 1; too often I get this
Thanks for reporting this, that should be easy for me to fix. For the time being you'll need to adjust the script using something like:
if ( moi.view.lineWidth > 1 ) moi.view.lineWidth -= 1;
4786.3 In reply to 4786.2
Thank you Michael. This and the option of round line caps plus the high resolution screenshot to clipboard would allow some nice shaded NPR renderings.
Alternatively if hidden lines are not exported to Illustrator I could change the line caps there.
4786.4 In reply to 4786.3
Hi Martin, something like rounded end caps may happen eventually in a sort of offline render method where it would calculate an image but which may take a while longer to generate than the regular real-time viewport display. It's a big focus for the regular display to do its job quickly and that tends to put some limits on what I can handle there.
But most likely I will be trying to focus on generating a hidden-line output to Illustrator first before stuff like that happens directly in MoI.
we can also change the parameters moi.view.lineWidth = 1; & moi.view.lineWidth = 4;from the srcript
Show messages: All  1  2-5
