SubD Ex;port
 1-15  16-35  36-44
478.16 In reply to 478.15
> Yea so it has to be like normal NURBS, where the mesh object is treated as a NURBS suface...
Except that you would get one of the major benefits of Sub-D over NURBS - your control hull could be set up with a much more arbitrary topology instead of only an M x N grid of points. This would be good for creating things like smooth branching structures. Well, and everything that SubD is good at doing right now.
It would be an alternative method for creating the base NURBS object.
> Anyway, the quad cage construction of a NURBS objects, can't you have any number
> of points on each side of the quad? Like when you make a sweep?
Yes, you can any number on each side, but the points have to be in a grid organization. So that's why you can't take just any polygon mesh and turn it into NURBS by using just the control points of the polygon mesh directly. A random polygon mesh doesn't always have a regular M x N grid layout to it.
For the places in a Sub-D surface that do naturally correspond to a NURBS surface, each quad face of the SubD cage becomes a NURBS surface with a 4x4 control point grid.
> but I thought the big advantage of NURBS was that you could define each
> side of you plane with more points and make it blend with 2-rail sweeps...
That you can define a single patch where each side of the plane with any number of points is a big advantage of NURBS over _Bezier_ surfaces, not over Sub-d surfaces.
Although I guess in a certain sense it does tend to organize things into larger "patch" objects in a natural way which kind of simplifies certain construction-oriented modeling approaches, like there is naturally a longer edge along one side of a sweep instead of a bunch of little tiny edges you would have to chain together for Sub-D. I guess that is kind of a user-interface issue with Sub-Ds - less restriction on topology is not automatically 100% better for all modeling strategies because restrictions on topology have a side effect of creating a type of natural grouping which is suited for certain things.
But for comparison between NURBS and Sub-D, I'd say that the single big advantage to NURBS is the well-defined trim curve mechanism, which is one of the fundamental things that makes stuff like trimming and booleans work well, and having a natural curve-on-surface structure is important to several other operations such as fillets as well.
> so I guess Maya has some special algorithms to handle that.
Yeah, from what I've seen they subdivide a few extra times near the "extraordinary point" (this is what a point shared by other than 4 neighboring faces is called). Each of these subdivisions generates more regular quads and shrinks the difficult area to be smaller and smaller. Then they have some kind of surface fitting mechanism that tries to get a good approximate NURBS surface for the final bit.
> I wonder if Max's NURMS (Non-Uniform Rational MeshSmooth) is catmull-clark sub-D....
I don't know... Probably, it is the most popular subdivision algorithm by far, although there are other methods around.
478.17 In reply to 478.16
I'm sorry I keep bringing up the questions, I'm just a very curious guy, I hope it's alright.
Is there a problem with making 3-sided NURBS patches?
And I'm not use I understand why it has to be a grid layout..
Does that mean it's possible to make a 100% quad-based mesh that wouldn't easily be turned to NURBS through this Sub-D method?
478.18 In reply to 478.17
It's alright. :)
Well, technically there is no problem making 3-sided NURBS patches. There is such a thing where the points are arranged in a kind of triangular grid instead a rectangular grid.
But they are not commonly used because none of the standard file formats allow for them - the standard file formats for transferring NURBS only allow for rectangular style NURBS surfaces.
So that's one reason why the normal way to do a 3-sided patch is to actually do a 4-sided patch with one side compressed down to a point.
Well, it is fundamentally the way a NURBS surface is defined. Having a grid layout makes the surface behave kind of like a grid network of curves. Like imagine taking one starting curve at one edge, then if you sort of step that curve along the other direction it will sweep out a surface - that's pretty much how a NURBS surface works.
Each NURBS surface has a 2d "parameter space" coordinate system defined along with its 3d points - the rectangular layout is what provides the 2d parameter space portion of the NURBS definition.
I'm not sure if I understand this question, but it is possible to have all quad faces in a mesh but still have points that are shared by more than 4 common faces, like a center point with quads spiraled around it - this again creates an "extraordinary point" that doesn't have a simple automatic NURBS conversion for these faces.
478.19 In reply to 478.18
Ah ok, now I get it :) Nearly... :S
NURBS objects have 2 kinds of points, one kind that can be added along the edge of a patch, and one kind that is the corner of a patch, right?
So it works like bezier patches, just with more advanced edge curves (and different interpolation)?
Do you know anywhere where I can read about the fundamental methematical structure of NURBS? So I can understand how it's handled and interpreted mathematically. Just the concepts, not something where I have to understand some advanced math formulas. Haven't had advanced math for a few years now :)
EDITED: 18 Mar 2007 by ELF
478.20 In reply to 478.19
Well, not just a corner. I guess one thing that is tricky is the names for things. A full NURBS modeler that supports booleans does not just support NURBS surfaces, but actually something more exactly called "Trimmed NURBS surfaces", which includes multiple parts - a NURBS surface + trim information.
There are a set of points for the NURBS surface, and there are a different set of points for the trimming curve information, so yes those are 2 different kinds of points.
Here for example is a simple NURBS surface without any extra trims. In this case the edges run along the natural edges of the surface. You can see here the control point structure of the surface:
Here is the same surface after it has been trimmed. The same surface is still there "underneath" everything, the trim curves are defined by a different set of points than the ones that make up the surface:
Bezier patches are related and very similar, except there is a much more strict limitation on the number of points that can be in one single Bezier patch. So to make a big long flowing surface only out of beziers will require making a bunch of smaller Beziers stuck together. NURBS surfaces improve on this by allowing any number of points (in one of the grid directions) so it makes it easier to make one big flowing surface.
Actually it is possible to dice up a NURBS surface into smaller Bezier pieces. NURBS are kind of like a method to manage a string of Beziers but in such a way that each Bezier is guaranteed to connect up to one another in a smooth manner.
Then the "more advanced edge curves" part is the trimming mechanism. This is kind of an additional mechanism layered on top of the basic NURBS surface.
About shared edges - that is another level of information to the trim curves. If you have 2 trim curves from different surfaces that touch one another (like they were calculated from an intersection between the surface for example), there can be some information stored that keeps track that these 2 surfaces share a common edge. This is what provides for making a logical "solid" out of a bunch of trimmed surfaces - if every edge is a common edge shared between 2 surfaces you have a connected skin of surfaces that defines a volume.
Hmmm, maybe Wikipedia?
A lot of computer graphics textbooks will cover it.
This is kind of a high level overview: http://rhino3d.com/nurbs.htm
I think this one is one of the best online articles about how NURBS curves work: http://devworld.apple.com/dev/techsupport/develop/issue25/schneider.html
478.21 In reply to 478.20
Thanks for the info :) Though I kind of understood all of that...
What I kind of didn't get was whether or not you could have points places like thpose in the attachment.
Because if you make a 2-rail sweep, you can have any number of points on each side.. but is that because the 2-rail sweep actually makes an entire grid of patches? Damn I just realised that :S Stupid me...
What I don't get then is why you can't do the same with bezier patches... have 1 side made of 2 points, one parallel maybe of 4 points, and 2 conneting those with sides with 3 and 5 points, and still get the computer to automatically generate a perfect smooth surface...
Oh and BTW... Aren't solids modelers often just NURBS modelers with good trimming? :P Like solidworks, or PowerNURBS/PowerSolid...
478.22 In reply to 478.21
No, not in a standard NURBS surface. This is the kind of thing that the T-Spline guys are working on as an extended type of NURBS surface, but the classic standard style does not allow for single additional points anywhere in the middle like that, if you want to add a point to a standard NURBS surface you have to add an entire row or column of points.
I guess the confusing part here is that there is a point matching and refining process that happens during the 2-rail sweep.
So even though your initial rails of the 2 rail sweep can have any number of points, the resulting surface does not use those control points directly, there is a process where the swept surface is shaped to conform to those curves by an ongoing refinement. On each step of the refinement, there is an entire row of points added to the surface being calculated.
So if you turn on the points of a swept surface, you will see that they are in a grid and that they don't match the original rails for example. For multiple profiles there is a process where all the points of the profiles are merged together so that there is a common number in that direction as well.
So the initial curves with different numbers of points don't just go directly into making up the surface.
Well, the computer has to manipulate something to make a perfectly smooth surface.
If you have a bezier surface made up of just 2 points for example, that is limited in the type of shapes it can make, you can make a plane with it or a kind of limited curve if the points are not on the same plane, but there are not enough points available in a 2-point structure to adjust it to make it connect up smoothly to something that is wiggling around a lot.
It's like saying you should be able to take a 2-point line segment in the middle of something and make it smooth by changing the points. But you can only connect 2 points in a straight line, you can't make 2 points form a smooth curve.
It is possible to make Beziers have more points to give the computer something to edit to manipulate the shape. But this tends to be clumsy because it means you have to lock down the location of a whole bunch of points to make them smooth with the adjacent patch. Pretty soon you can only make clumsy edits because most of the points are locked down to provide smoothness.
Yes, 99% of "solids" modelers are NURBS based, with trimmed NURBS surfaces and "B-Reps" (Boundary-representation) which is the name for trimmed surfaces + the ability to have shared edges beween surfaces.
But a lot of solids modelers tend to incorporate other layers of mechanisms in them such as constraint-based solvers where you can tag certain dimensions to be rigid and have it calculate other dimensions for you, and many of them sort of present a particular style of user interface for how you interact with objects. By this I mean they don't tend to give you access to stuff like the individual control points on the NURBS surfaces even though they are using those behind the scenes.
So there tends to be a package of additional mechanisms and certain types of workflow associated with the "solids" modelers.
478.23 In reply to 478.22
Ah damn, I don't get it :S I don't get why you can't 2-rail sweep-generate a bezier controlled patch surface... in all it's simplicity, is it because the points are too complex? B-splines are only defined by a point in space, while beziers are 4 vectors in space, right?
I'm sorry, I just didn't understand anything of what you wrote :S
478.24 In reply to 478.23
It's just more difficult to create longer surfaces out of Beziers because each individual Bezier is limited in the number of points it can have in it, so you would have to use a bunch of them stuck together, with the points carefully arranged to try and make them smooth.
NURBS was basically invented to solve this problem, it is a way to have a longer string of points than a bezier can have in it.
No, Beziers are also defined by points in space. Sometimes they may be displayed with stuff that looks like vectors but those are just lines connecting between the points.
A Bezier surface looks the same as a NURBS surface, it is a rectangular grid of points just like a NURBS surface.
But a bezier can only have as many points as its "Degree" + 1. The "Degree" is one part of the definition of a NURBS or Bezier, it defines the highest exponent of the math function used for the blending calculations.
So a degree 3 bezier curve is made up of 4 points. You can only make so many shapes with 4 points, to make more intricate shapes you need to use more points, which for beziers means trying to stick together a bunch of separate beziers.
NURBS allows for more points, if you have a NURBS curve of degree 3, it can have a minimum of 4 points (which makes it equivalent to a bezier), but it can have any number more than that. The NURBS blending method makes it easier to get a smooth result curve from a longer chain of points, it is built in to the smoothing formula, instead of being something that you have to do manually by arranging points which you have to do if you stick small bezier curves next to one another.
478.25 In reply to 478.24
Hmm, I THINK I got it now...
What do you mean with an individual bezier? a bezier point? patch?
Damn this is hard to grasp :S I might have more questions for your reply later...
478.26 In reply to 478.25
I meant patch. Or curve if I was talking about curves instead of surfaces.
478.27 In reply to 478.24
Ah crap, I still don't get it :S
So you say a NURBS patch is limited to 4 sides... well so is a NURBS patch, right?
I don't quite understand this bezier limitation... can't you have any number of patches in a grid with both NURBS and bezier?
You usually stick beziers together in groups of... 4? or 2? (maybe just 1?) Representing a cross-section in a grid. each of these consist of 3x4 points (one for corner position, and 2 for defining curvature), these are treated as 1 point with 4 "arms" in for example 3ds max.
3ds max usually locks the arms 2 by 2, Like this:
The normal represented by one arm is continued over in the superjacent arm so if you draw a line between the 2 points it will go through the middle "position" point.
So you're sure you'll have at least 2G (?) continuity.
So you might in reality have several points, but in practice you only have 1 point with 2 "vectors" (1 vector defining length from and angle/normal to middle point, for each two superjacent points).
I don't get why these points couldn't be interpolated in a sweep just like the b-spline points in a NURBS swept surface...
478.28 In reply to 478.27
Both Beziers and NURBS have a rectangular type 4-sided grid, yes.
Sure, you can stick together a bunch of little surfaces with either method.
But with Beziers you are forced to stick together a bunch of little separate surfaces. With NURBS you have an alternative - you don't have to stick together a whole bunch of different NURBS surfaces, you can have one single NURBS surface that is longer.
For instance the result of a sweep is just one single NURBS surface, not a whole bunch of little NURBS surfaces arranged together. With Beziers you are forced to do the "whole bunch arranged next to each other" method.
Those 2 inside points immediately define the tangent direction only, not the curvature.
Nope - in fact that is the big problem you are only guaranteed to have G1 / Tangent continuity with this method of bezier arrangement, unless you do another further lockdown of making the points on either side equal distances from the corner point.
On the other hand a NURBS surface made up of a longer number of points in one single surface is able to have G2 curvature continuity throughout the entire surface, without doing any kind of special "lockdowns" or spacing restrictions on the points that you can move around.
The typical "chain of beziers" mechanism results in shared tangents only between each piece, usually these chains have breaks in curvature between each bezier piece. That's one reason why MoI doesn't use the 2D illustrator style bezier curve drawing, because it does not generate a G2 result curve.
Well you could do it. But it is not commonly done since there are all these kinds of restrictions on how the resulting points have to be arranged. If you pull on one point in the resulting Bezier patchwork, a bunch of other points nearby have to be moved along with it and re-arranged. This is just clumsy in general from several viewpoints, both from code implementation as well as user interface.
NURBS solves this problem by making it possible to have a surface with more than 4 points in it without requiring a bunch of point restrictions and point "lockdowns".
478.29 In reply to 478.28
Ah nice :)
Thankyou really much for all the info, it's been really informative.
Hmmm, now to learn the math behind sweeping, and then coding a script for 3ds max so I can do it with polies :P Shouldn't really be that different from NURBS' way of doing it, right?
And then I'll just have to wait for npower software to implement the Sub-D -> NURBS feature I suggested that they seamed to like very much, and then I'll have perfect NURBS/Sub-D collaboration within max!! Though I'll most likely still be doing my NURBS stuff in MoI... I just hope I can afford a license when it comes to that :S
478.30 In reply to 478.29
ELF:
Well, you better don't wait for Npower to implement SUB-D into PowerNurbs because i already suggested that a long time ago for Version 2.0 in 2005 http://npowersoftware.com/forums/showthread.php?t=425 and although they liked very much the idea - they didn't intergrated it! Then again the same discussion about Sub-D came almost a year later in this thread http://npowersoftware.com/forums/showthread.php?t=580, and again it just seems they liked the idea but don't want to implement it...
So again ELF, i don't think they will implement it, they just always say it is a great idea... But who knows, maybe they will realize this time, what possibilitys that would open - for us and for them!
Michael:
Wouldn't that be a option for MOI?? A SubD-Nurbs Hybrid? With the best of both Worlds? Like they did in Catia?
For Inspiration please visit http://www.3ds.com/news-events/spotlights/catia-for-style/overview/ for a little overview Video and then the actually presentation site with modeling example videos http://www.3ds.com/flashgallery/imagine-and-shape-v5r17/
Do you think it would be hard to implement?
I really wish somebody would make it possible for us...
FP
478.31 In reply to 478.30
I think it might be a bit too much for Michael to do for V1... or V2 for that matter :S
Lets just hope it's pushed through... with several demands... or that someone beats them to it...
I bet there's a whitepaper or some other research out there on a good technique for solving the problems Michal and I discussed in the last few posts... a stand-alone plugin for 3ds max would really be nice...
Michael:
I gotta ask.. as far as I understand you're quite the guru when it comes to NURBS programming. Could you give me a hint where I might find some info on coding such a poly sweep function? Sweep and nice booleans are the only 2 things I feel poly modelling (in max at least) lacks to be perfect.
I understand if you won't help though. I kind of feel I'm saying "Hey, won't you tell me how I can make a solution so I can make what I want without buying the software you put so much work into".. But I hope you understand that I will still be quite the NURBS fan, especially with the simplicity of MoI...
478.32 In reply to 478.30
> Michael:
Well, notice that one of the things that Catia did is they have a separate modeling module for doing the SubD sculpting portion, then they enabled importing that as NURBS geometry into the other regular modeling modules.
It's pretty hard.
Actually the most difficult problem is that the tools and workflow that you use for SubD modeling is pretty different from regular NURBS drawing/construction type tools. It will be very challenging to combine all those tools into one single interface without it being a big complex mess.
That's actually probably the single largest problem - Catia seems to have side-stepped this by having their Sub-D modeler set up as a separate application instead of having all functions directly combined into one app. Also some fancy tools like Catia don't really mind as much about having a complex UI as I do.
It won't be easy for me to undertake this huge of a UI design anytime too soon. I'd say that it would be quite a few years away at a minimum.
As far as the geometry goes, that is also not a completely simple thing to do, that will take some finesse work as well, but I think that eventually there would be more geometry library support for this type of stuff as it becomes increasingly common.
478.33 In reply to 478.31
:) I can definitely say that it's too much for V2 as well. There is still a lot of ground to cover for non-Sub-D NURBS modeling.
It will be quite a ways out before it will be possible for me to work on this type of hybrid functionality for MoI.
Well, some older names for 2-rail sweeping is "birail", so you might do some searching using that term.
"The NURBS Book", by Les Piegl and Wayne Tiller have a section on one-rail sweeping. They give a couple of references:
Sweep surfaces modelling via coordinate transformations and blending : http://portal.acm.org/citation.cfm?id=87207
V Akman, A Arslan, Sweeping with all graphical ingredients in a topological picturebook, Computers & Graphics 16(3): 273-281 (Fall 1992) [WOS]
Try searching scholar.google.com and ACM for papers about "sweeping".
I think the Hexagon modeler implements these kinds of features for polygon modeling, so you might look over there to see what they have done.
Are you expecting to do this sweep function on polygon line segments, or on curves? Doing it on polygon line segments will probably introduce a lot of different issues because one part of the sweeping function is usually a recursive adaptive fit to the rails, where you start with a coarser version of the sweep and continue to add in points to refine it until it hugs the shape of the rail curves to an acceptable degree. If you want to match polyline rails, it would probably be expected that you would use only those existing segments for your rail curves instead of refitting completely new ones. That introduces a kind of different complication to the whole thing.
In general one of the parts that you will have to solve at first is how to synchronize the point structures of the curves involved.
Sorry I won't able to really help you with this, I just don't have the time available for that type of a thing.
478.34 In reply to 478.30
I was really impressed by the Catia demo. I think it follows the standard sculpting workflow of most SubD apps, but includes better tools for manipulating hi-res hard surface objects. Most SubD sculpting apps coming out now focus primarily on brush tools. I would like to see if Catia can handle complex boolean operations like PowerNURBS's Detailer can. On their Phone modeling tutorial they literally boolean text into surfaces, which is something I would never try with SubDs.
But like I said, Catia seems to be based on a sculpting worklow and I think MoI is attempting to create a drawing based modeling workflow; much like SketchUp has done.
I don't see the word "Nurbs" in the Catia-Inshape Poduct overview?
just"subdivision surfaces"
Are they integrated?
http://www.3ds.com/products-solutions/plm-solutions/catia/all-products/domain/Shape_Design_Styling/product/IMA/
and that cost something like 20 000 $ (?) :)
EDITED: 22 Mar 2007 by PILOU
Show messages:  1-15  16-35  36-44
