Funny thing!
All  1-7  8-10
4775.8 In reply to 4775.4
Michael,
as usual, your tips are very useful. To get a pseuso render real quit like that is a great idea, thanks.
I suppose I can shrink (scale down) my second profile such that it doesn't fold on itself like it does now but this will also affect other aspect of the model that I'd prefer not modify if possible. I did this to create the red model kind of thing in the last image I posted. For this first attempt I used an open profile curve to generate the sweep, I was just fooling around and then decide it would be nice to use 2 of these objects and join them with a nice flowing shape to connect them. I realised I needed a symmetric profile curve such that it would be possible to use these profile as well for the connecting part.
Personnaly, I have 2 problems with this models, the first is obviously the self intercecting part and the second is that a real object like this wouldn't have empty space like it's clearly visible in your image (felix_self_intersection3.jpg). I guess my question would be, is how can we design such object without self intersecting part and with no voids? Any suggestion will be helpful, I have no doubt about that.
Felix
4775.9 In reply to 4775.7
Michael,
thanks for the explanation about internal data and saved data. I guess we must avoid self intersecting part at all cost if we don't want to get into trouble.
Felix
4775.10 In reply to 4775.9
Hi Felix, you can actually make a self-intersecting object if you only want to make a render mesh for it, but yeah they need to be avoided if you want to do things that will involve surface/surface intersection calculations with the object such as booleans.
This is certainly a tricky shape to try and make without self-intersection though.
I think you'll have to stop the main sweep something around here:
And then make the rest of it with just the outside half portion of the profile, something like this:
Or maybe you could try only doing a half profile (the outer half) along the entire sweep length and then an inner profile that stops before it folds in on itself, and then do a blend between them to connect them up.
Show messages: All  1-7  8-10
