Supershapes / SuperFormula
All  1-6  7-12
Edit: Deleted the old script, due to poor programmer understanding of when/where to do updates to factory/factories.
Moved the factories update out of the i and j loops, and added a simple factory update. Much faster performance.
Attached improved script.
Edit, revised script in post 10 below.
EDITED: 22 Jan 2014 by BEMFARMER
Seems there is a glitch! :)
4766.9 In reply to 4766.8
I'll have a look. Probably the index needs adjusting.
Made some modifications to this 2 year old script, which was of learning benefit back then.
The script has a lot of variables.
Roughly speaking, for 100% of a 360 degree set of curves, the new version avoids a duplicating overlap of the first and last drawn curves, by not
drawing the zero-ith curve. It will also do a percentage of a 360 degree set of curves, for example a 180 degree set of curves, including the zero-ith curve.
The default htm uses Pilou's example, with uDensity = 9, for creation of 9 curves.
Had quite a difficult time adjusting indexes.
Excellent!
Show messages: All  1-6  7-12
