Help with filleting
All  1-8  9-12
4734.9 In reply to 4734.8
Please Bigseb
Could you show in a tutorial complete proceedings since the creation of curves please? I want to improve my knowledge of MoI and I am sure that this can help me much.
4734.10 In reply to 4734.1
Hi Sebastian - yeah the folds that Burr shows above will cause numerous problems with surface/surface intersection mechanisms - many operations such as trimming, booleans, or filleting will not usually work right on surfaces that are messed up in that particular way.
I don't see any of the original generator curves used to create that surface still in this file - you'll probably want to check those curves out and make sure that the original curves that were being used don't have a folded over area in the curve - if it does then usually surfaces created from that kind of curve will inherit the same problem as well.
4734.11 In reply to 4734.9
Mercar,
Sure, it'll take a while though. The images you saw in this thread are for a celtic ring which I am busy rendering at the moment. I may still make some changes, but they'll be more or less in line with what I have now. Keep an eye on the galleries page ;)
4734.12 In reply to 4734.10
Michael,
Thanks, got it sorted now. :)
Show messages: All  1-8  9-12
