Attached is a basketball script, used to generate the "seam lines", (should be grooves), for a basketball.
Used the corrected formula from <http://www.3d-meier.de/tut9/Seite14.html> , which is the intersection
of a sphere and a hyperbolic paraboloid. (formerly done in C4D ?)
(Modified from Michaels ToroidalHelix script, MoI program)
From wikipedia: "The standard size of a basketball in the NBA is 29.5 to 29.875 inches (75 to 75.88 cm) in circumference."
Radius = circumference / (2 * pi) (75.5 / 2pi = 12 centimeters +/-.
MoI set to centimeters.
The script creates sparse points in some areas, so numpoints was increased to a highcount 2000, then used
Rebuild at .01 cm to reduce 2000 numpoints to lower value.
Create sphere and rotate so joint occurs at two added circles.
Note: aValue is approximate, would need to adjust aValue to match regulation ball pattern.
Would need to change lines to actual groove in ball.
The aValue used is considerably different, (higher,) than the value used in the German web site. Why ?
Sphere of radius 12 was created, and rotated so seam matches two other added circles.
To adjust script groove, a person can load the basketball.3dm file, and erase seam, and re-run script.
Or else practice MoI, making the ball from scratch.
Texturing and grooves not done...
