octopus rail revolve
4724.1
Hi all gurus !
I try to create a octopus but i don't get it right... the sketch I made in Cinema4D (lower right picture) so you understand what's shape i'm trying to achieve. Please put me on right track.
I start with a shape in topview and a rail in front view and then I tried to Rail Revolve but i dont achieve the right shape. How should I do that ? Thanks in advance !
/ urban
Size: 45.8 KB, Downloaded: 164 times, Dimensions: 800x605px
4724.2 In reply to 4724.1
Hi urban - I think you've got your curves there selectedin the wrong order.
For rail revolve you want to have the profile be the curve that touches the pivot axis, and the closed curve going around the whole circumference should be the rail curve and picked 2nd instead of picked 1st.
So start out with just the curve in the Front view selected - then run rail revolve and then for the rail curve select the closed curve in the top view, then the pick the revolve axis points.
The result you're getting is because it's trying to revolve the closed curve around the shorter one when I think you want the opposite to happen.
4724.3
Thanks Michael !
Now its work much better , I wish you a nice weekend !
/ urban
Size: 226.4 KB, Downloaded: 96 times, Dimensions: 800x500px
