3D pdf
All  1-2  3-15
4718.3 In reply to 4718.2
Thanks for recommendation Michael.
4718.4
Know of any freeware 3D model viewers?
Michael T.
4718.5 In reply to 4718.4
Even with a pdf solution to a quick-viewer for 3d models, you still have to have the pdf view loaded on each operating system that the model is to be viewed on.
I know pretty well, that a script can be set up to both expand the UI in MoI and do something cool like auto-rotate. The auto-rotate script is pretty snazzy BTW.
I bet there could be a way to use this ability with MoI to show off a model.
Maybe not from a purely executable standpoint, but maybe from a command line run. ???
MoI's clean and anti-aliased viewing of NURBS models is hard to beat.
4718.6 In reply to 4718.4
Hi Michael T.
Well, Adobe Acrobat Reader is one, it can view 3D models since a couple of versions ago. The good thing about that one is that a lot of people already have it installed in order to view 2D PDF files.
There are various other viewers out there as well, but using the Acrobat one is probably your best bet for one that might not need any further installation done.
4718.7 In reply to 4718.6
Hi Michael G.
I was wondering about freeware viewers for other 3D formats such as 3DS or OBJ, etc. files, rather than 3D PDF. Something that would not require 3D PDF generation.
Tryin' to get by cheap (or free!) :-)
Michael T.
Seems the free Meshlab can read all these formats or other and make also more things :)
http://meshlab.sourceforge.net/
sure it's not a "real viewer" but result is the same :)
4718.9 In reply to 4718.8
Thanks Pilou. I'll try this when I get a chance later.
Michael T.
4718.10 In reply to 4718.9
GLC Player is also nice viewer and free:
http://www.glc-player.net/
4718.11
Thanks! I'll try this one later as well.
Michael T.
4718.12 In reply to 4718.7
Hi Michael T - well you could send whoever you want to view your model a link to the MoI "no save" trial version which they could then install and use to open up your main 3DM file.
The direct link to that one is here:
http://moi3d.com/2.0/trial/moi_v2_nosave_trial_setup.exe
There's a freeware viewer and converter program here that loads IGES or STEP files:
http://iges2step.narod.ru/
You can probably find a few other OBJ viewers by google search, like:
http://www.aweapp.com/obj_viewer/
http://pti.iu.edu/avl/GLM_AVL
Or probably the trial versions of various different programs might work, like you could use the trial version of Silo (http://www.nevercenter.com/silo/) for an OBJ viewer.
4718.13
Simlab also has an OBJ viewer for the IPad if interested, it's almost free for $2.99
http://itunes.apple.com/us/app/simlab-3d-obj-viewer/id443802553?mt=8
4718.14 In reply to 4718.12
Thanks Michael G.
4718.15 In reply to 4718.13
Hi Danny,
Too bad I don't have any Mac products :-)
Michael T.
Show messages: All  1-2  3-15
