Combine same named objects
All  1-10  11-14
4709.11 In reply to 4709.9
There's also a different OBJ importer available for Cinema4D called Riptide here:
http://skinprops.com/riptide.php
It doesn't seem to split these objects with the same name up either though, but it will also import materials from OBJ files so when using the Riptide plugin for doing the import style colors that you assigned in MoI come through into C4D.
4709.12 In reply to 4709.11
Yeah Riptide is the plugin to go for indeed. I used to use the free version but that one does not work with the latest version of C4D.
But for a little amount of money you can buy the pro version. Highly recommended by me.
Peace,
Rich_Art. ;-)
| C4DLounge.eu | Our Dutch/Belgium C4D forum. Cinema4D R13 Studio + VrayForC4D + UVLayout Pro + 3DCoat
4709.13 In reply to 4709.11
I still use the "object name separator" script Michael wrote here:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=3114.1
The script is in post #5 and you need to have your object boolean unioned and
other elements of the object can be isolated with styles.
EDITED: 13 Nov 2011 by SBEECH
4709.14 In reply to 4709.13
If you leave your objects unnamed, they will also get auto numbered at export time with names like object1 object2 object3, etc... for each different object.
Show messages: All  1-10  11-14
