Rhino on OSX now compatible with Moi
All  1-3  4-12
4689.4 In reply to 4689.2
I have Parallels, which works fine, but prefer to work with MoI directly under Bootcamp/Win XP.
4689.5 In reply to 4689.4
The good thing about the Wine method is that it loads and executes code directly, it doesn't run inside of a "virtual machine" type layer. The only time Wine actually gets involved is when the program makes API calls, other than that it stays out of the way so basic number crunching code happens at full speed.
The main problem with it is that it does not perfectly recreate the regular Windows API behavior.
4689.6
I've been using Parallels since version 4 and it runs @ 100% on my Mac Mini with Moi. Version 4 can also be found a bit cheaper than the current version 6 if you like bargains! I allocate Parallels 2GB of RAM out of the 4GB installed in the machine and it can easily handle the fairly complicated drawings that I have done.
Moi is the only Windoze program I run, and I will do anything to keep it that way. LOL
Cheers,
Chris
4689.7 In reply to 4689.3
Hi Michael, you own a Mac and you're experimenting with WINE? Do you see the big smile on my face? Not having to start VMWare or dealing with Windows in order to use your great software would be too good to be true. This and improved 2D export.
Just yesterday out of curiosity I purchased WinOnX (winonx.com) from the Apple Appstore. It's some sort of WINE made simple for OS X users. I was able to install MoI 3 beta but when I started it I got the attched message.
I'll keep my fingers crossed and hope you can offer MoI for Mac users one day. There are more than two :)
4689.8 In reply to 4689.7
Hi Martin, yes I'm really close to having a prototype version of a Wine-based OSX version that won't require VMWare or Parallels to run anymore. I'll probably have something to test with in just a few more days here.
That means that MoI could not find the Direct3D 9 system DLLs that it uses to access the Direct3D system. That means that either WinOnX is using a pretty old version of Wine or it has disabled Direct3D in its Wine build, which would not be too surprising since there are some problems with Wine's D3D system on OSX in particular. It looks like I will be able to avoid those problems with just a couple of minor tweaks to MoI though.
But anyway I should have something for you to try really soon here.
4689.9 In reply to 4689.8
:) Thanks Michael
4689.10 In reply to 4689.8
I'm here for testing :)
4689.11 In reply to 4689.10
Me too; yes, include me too please!!!
Cheers,
. Diego .
You can try an OSX v3 beta now from here:
http://moi3d.com/osxbeta.htm
Show messages: All  1-3  4-12
