Why does this not work...
All  1-6  7-8
4687.7 In reply to 4687.6
Thanks. I got it to work though. Cheers anyway!
4687.8
In your model, the thread obeject is not joined properly. It has an open edge running as a spiral round the thread. If you redo the thread so that this doesn't happen, then slice of the ends with a trim, you can add planar ends to make a solid. This solid will then boolean from the block.
Show messages: All  1-6  7-8
