Why does this not work...
All  1  2-8
4687.2 In reply to 4687.1
Hi bigseb,
Your shapes are "open surfaces". There is not a cut that can be made by that open screw thread ..
4687.3 In reply to 4687.2
Ok... meaning? What do I do to fix? Surely there is a way?
4687.4
Hello,
Were you looking for something like this?
4687.5 In reply to 4687.4
Sort of. I want to trim B with A, then trim C with B.
Size: 245.8 KB, Downloaded: 33 times, Dimensions: 1920x1080px
4687.6
Hello,
So something more like this?
4687.7 In reply to 4687.6
Thanks. I got it to work though. Cheers anyway!
4687.8
In your model, the thread obeject is not joined properly. It has an open edge running as a spiral round the thread. If you redo the thread so that this doesn't happen, then slice of the ends with a trim, you can add planar ends to make a solid. This solid will then boolean from the block.
Show messages: All  1  2-8
