Instances ? Blocks ? When ?
All  1-4  5-9
4671.5 In reply to 4671.4
Hi DesuDeus,
> Yeah but once you used MoI then Rhino feel so old... I can't even
> load one of my model into Rhino while I can load it perfectly in MoI !
> So it's kinda hard to do everything in Rhino at the same speed
> than in MoI :)
:) Sure I can understand that.
But really one big reason why MoI has that whole feeling to it is that I try to avoid just sticking a ton of features into it without carefully considering how they fit together and how they'll behave in the long term.
Instances is a really big feature area - implementing it will involve stuff in the display engine, probably stuff in selection, UI and workflow to design to manage them, and probably will impact file I/O in several ways as well.
So it's a really big feature that requires work in an unusual number of different areas.
When doing a really big feature like that, it needs to be planned really carefully so that I don't end up doing it in a wrong direction.
I do expect to have it eventually, but I'm not sure exactly when.
4671.6 In reply to 4671.5
just wanted to express my wish for instancing as well... (in a way that the original can be reworked and all the instances update)
I guess this is not too easy to implement, but every now and then it might be really helpful.
What you see is what you believe - so don't. (from an Amiga500 demo)
4671.7
Instancing would be great :)
(obviously)
Is it on the V3 or V4 list?
4671.8 In reply to 4671.7
Hi NightCabbage,
It's on the big list, but I'm not sure when it will happen for sure, there is quite a lot of work involved for it.
In the more nearer term stuff for v3 I'll most likely be more focusing on more surfacing and model construction type tools as a higher priority first.
4671.9 In reply to 4671.8
Cool ok :D
I imagine it would be a lot of work to implement something like that :P
Show messages: All  1-4  5-9
