Instances ? Blocks ? When ?
All  1-2  3-9
4671.3 In reply to 4671.1
Basically the Rhino block mechanism is just copied directly from AutoCAD and I'm not entirely sure if it's a totally great mechanism to follow exactly in MoI.
There's a lot of various quirks - like for example in Rhino you can't just select a block as input to regular command like doing a boolean with one, so if you wanted to use blocks as way to set up some pattern that you then want to cut into an object and then do some update of the block to update the cut pattern that is not possible to do in Rhino.
I'm not entirely sure though if that case is better dealt with by a history mechanism instead or whether that kind of sub-object component thing is really needed to be directly a part of the block mechanism or what.
So that kind of uncertainty pushes blocks off for a bit as well in MoI.
4671.4 In reply to 4671.3
Yeah but once you used MoI then Rhino feel so old... I can't even load one of my model into Rhino while I can load it perfectly in MoI !
So it's kinda hard to do everything in Rhino at the same speed than in MoI :)
4671.5 In reply to 4671.4
Hi DesuDeus,
> than in MoI :)
:) Sure I can understand that.
But really one big reason why MoI has that whole feeling to it is that I try to avoid just sticking a ton of features into it without carefully considering how they fit together and how they'll behave in the long term.
Instances is a really big feature area - implementing it will involve stuff in the display engine, probably stuff in selection, UI and workflow to design to manage them, and probably will impact file I/O in several ways as well.
So it's a really big feature that requires work in an unusual number of different areas.
When doing a really big feature like that, it needs to be planned really carefully so that I don't end up doing it in a wrong direction.
I do expect to have it eventually, but I'm not sure exactly when.
4671.6 In reply to 4671.5
just wanted to express my wish for instancing as well... (in a way that the original can be reworked and all the instances update)
I guess this is not too easy to implement, but every now and then it might be really helpful.
What you see is what you believe - so don't. (from an Amiga500 demo)
4671.7
Instancing would be great :)
(obviously)
Is it on the V3 or V4 list?
4671.8 In reply to 4671.7
Hi NightCabbage,
It's on the big list, but I'm not sure when it will happen for sure, there is quite a lot of work involved for it.
In the more nearer term stuff for v3 I'll most likely be more focusing on more surfacing and model construction type tools as a higher priority first.
4671.9 In reply to 4671.8
Cool ok :D
I imagine it would be a lot of work to implement something like that :P
Show messages: All  1-2  3-9
